Has anyone had this happen before? When I insert the memory card, the spring just pushes the card back out. It doesn't click and stay in.
If I just close the battery door, the card works fine, but when I open the door, the card pops out again...
Jul 31, 2012 13:12 | #1 Has anyone had this happen before? When I insert the memory card, the spring just pushes the card back out. It doesn't click and stay in. Mike
Jul 31, 2012 13:47 | #2 That has never happened to mine. How old is it? Maybe you could bring it back to where you bought it, or call canon. I would get it fixed,
Jul 31, 2012 13:54 | #3 Have you tried inserting another SD card? If that other one still does not stay put, then it's repair time.
Jul 31, 2012 14:04 | #4 avigar wrote in post #14795912 Have you tried inserting another SD card? If that other one still does not stay put, then it's repair time. That's a good suggestion, trying another SD card, you never know.
Jul 31, 2012 15:51 | #5 Will try another one. Thanks for the suggestion. Still under warranty, so I can get it fixed, just trying to avoid that, as I already sent it out once for repair. Mike
conbu19 Senior Member 565 posts Joined Oct 2006 Location: NY,NY More info | Aug 02, 2012 15:06 | #6 Mike I know I'm a bit late to this but just in case...wnen my s95 was about two months old the same thing started to happen memory card would not stay in body...tried several cards, battery in battery out blah, blah, blah....sent it back to Canon they changed the whole board (which I assume holds the card recepticle no charge works perfect a year later.
Fontgod.com Hatchling 1 post Joined Oct 2012 More info | Oct 11, 2012 23:03 | #7 Just signed up in case this info helps anyone. A mate of mine has an S95 with the same problem (SD card not locking into place).
| Latest registered member is semonsters 1675 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
