Thread started 31 Jul 2012 (Tuesday) 21:06
Help
Lone-eagle
Jul 31, 2012 21:06 |  #1
How do I keep from blowing out the sky do I need a filter or is it in my setting
Dale
Canon XSi, 18-55, 55-250, 85 f / 1.8, 24-105 f / 4L
rick_reno
Jul 31, 2012 21:29 |  #2
got a sample shot?
MT59
Jul 31, 2012 21:33 |  #3
Yeah. Could go either way (or both). Depends on the shot.
5D2, 7D, 40D (all gripped), 24-105 f/4L, 70-200 f/2.8L IS Mk I, 28-105 f/3.5-4.5 USM, Sigma 8-16mm, Sigma 70-300mm
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jul 31, 2012 21:34 |  #4
rick_reno wrote in post #14797856 (external link)
got a sample shot?
This is important because there are several methods.
And what will you use for post processing?
Nature ­ Nut
Joined May 2012
Jul 31, 2012 21:36 |  #5
Exposing for the ground will usually result in blowing out brights like the sky or exposing for the sky will make the ground blacked out at times. You can try dynamic priority if your camera has it or look into HDR or a ND/CPL filter which may help depending on the conditions. The range of brightness your eye can see is much greater than what a camera can see.
Adam - Upstate NY:
ashiundar
Joined Jun 2011
Aug 01, 2012 00:51 |  #6
This is tricky. I set my camera to center-weighted metering and if I frame the image such that the center circle has half horizon and half sky and then meter, the exposure comes out roughly how I like it.
Like previously mentioned, some scenes have too much dynamic range for the camera to handle. A good way to resolve this issue, however, is to get a circular polarizer. I recommend B+W or Marumi.
ashwinsundar.com (external link)
5D || Elan 7 || 17-40L
tzalman
Fatal attraction.
Aug 01, 2012 02:18 |  #7
1. Shoot Raw.
2. Use the histogram. Place the sky so it is just starting to clip. (Raw has greater headroom than is indicated on the jpg-based histogram so it won't really be clipped).
3. In the Raw converter darken highlights and brighten shadows. LR 4.1 and ACR 7.1 are best for this.
Elie / אלי
Lone-eagle
Aug 01, 2012 09:09 |  #8
I have no samples I delete them
Thanks to all
Dale
rral22
Aug 01, 2012 09:53 |  #9
tzalman wrote in post #14798759 (external link)
1. Shoot Raw.
That's my solution if a graduated ND filter is not a better choice for the particular shot.
watt100
Aug 02, 2012 11:21 |  #10
1. Shoot Raw.
^^ meter for the sky and adjust foreground in post
Lone-eagle
Aug 02, 2012 12:21 |  #11
watt100 wrote in post #14804693 (external link)
Thanks Watt 100
Dale
1,767 views & 0 likes for this thread, 9 members have posted to it.
Help
604 guests, 122 members online
