Happened a couple of times now. It takes a couple of power offs and TC / lens removals to then work without the busy status?.
Anyone had this?
TIA
Jamie
shoshone Senior Member More info | Aug 01, 2012 11:41 | #1 Happened a couple of times now. It takes a couple of power offs and TC / lens removals to then work without the busy status?. Sony: A7rii
Jon_Doh Senior Member More info | Aug 01, 2012 14:47 | #2 You may have a bad contact on the TC or perhaps it's just dirty. Try cleaning the contacts on the coverter and in the camera and see if that helps. I use a Kodak Brownie
Aug 01, 2012 14:52 | #3 I had that issue with an 1dll canon replaced the mount on the tcmk2.
Aug 05, 2012 08:53 | #4 Jon_Doh wrote in post #14800930 You may have a bad contact on the TC or perhaps it's just dirty. Try cleaning the contacts on the coverter and in the camera and see if that helps. Thanks I'll do that Sony: A7rii
Aug 05, 2012 08:55 | #5 MajesticMomentsPhoto wrote in post #14800959 I had that issue with an 1dll canon replaced the mount on the tcmk2. Hmm I guess I'll try cleaning the contacts Sony: A7rii
| Latest registered member is semonsters 1600 guests, 142 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
