Thread started 02 Aug 2012 (Thursday) 05:58
Why IS barely work for Macro??
Earwax69
Joined Jul 2012
Aug 02, 2012 05:58 |  #1
Hi, I was wondering about why the IS can be so efficient on telephoto but so inept on macro lenses... Anyone know the reason??
Canon 6D | S35mm f1.4 | 135mm f2 The rest: T3i, 20D, 15mm f2.8, 15-85mm, 24mm f2.8, 50mm f1.8, 85mm f1.8, 90mm f2.8 macro, 55-250mm.
So long and thanks for all the fish
Eyal
Joined May 2011
Aug 02, 2012 06:24 |  #2
I'm not sure how you got into that decision.
I'm using the IS when I hand held my camera and the light is too low, and I'm not using a flash.
Using a tripod the camera doesn't move, so IS is pointless. Using a flash allows you to get faster shutter speeds, so the IS is not needed most of the time.
But who said its inept?
5DMarkIII+Grip | Extender 1.4x III / 2x III
16-35mm F/2.8L II | 24-70mm F/2.8L II | 70-200mm F/2.8L IS II
Σ 50mm F/1.4 | 85mm F/1.2L II | 100mm F/2.8L IS Macro | 135mm F/2L | 300mm F/2.8L IS
Earwax69
Joined Jul 2012
Aug 02, 2012 06:25 |  #3
Well, they say the IS is only good for 1 stop for macro... By they I mean the reviewers and people on forums.
By comparison, the newest IS lenses can do 4 stops...
Edit: Here from a review:
IS is not as effective at macro distances. Canon rates this IS system for 3 stops of assistance at .5x/2:1 and 2 stops of assistance at 1x/1:1. Testing IS completely handheld at 1x/1:1 is not easy - it is very hard to even keep the subject in focus when shooting completely freehand at this short distance. That said, at 1x with IS on, I get a good keeper rate at a shutter speed of 1/30 second and a few at 1/15. That is close to two stops for me.
http://www.the-digital-picture.com …SM-Macro-Lens-Review.aspx (external link)
I admit, almost 2 stops is better than no IS. Hopefully in the future we can see than number grow.
jeroenw
Gallery: 22 photos
Aug 02, 2012 06:35 |  #4
This is because the DOF is so thin with macro shots that the image goes out of focus when moving slightly forward and backward and the IS can't compensate for that.
60d, Σ30 1.4, Σ17-50, Σ50-150 OS, Σ150-600 (C)flickr (external link), fuji x10
Earwax69
Joined Jul 2012
Aug 02, 2012 06:38 |  #5
mmm, that make sens. That mean the IS is actually working but cannot compensate for the z-axis motion. Yes, that make a lot of sens! I wish i had a L lens to try it out!! :P
paddler4
Aug 02, 2012 06:41 |  #6
No, it is not because of DOF. DOF would matter only if you were moving the camera back and forth.
I believe it is because most IS systems adjust for angular motion, which has a big effect at long distances and a very small effect at short distances. The big problem at macro distances is movement parallel to the sensor. Canon's hybrid IS adjusts for this motion as well, which is why it provides a modest gain at macro distances.
When I was shopping for the 100L, which has hybrid IS, I wrote to Canon, and the person who wrote back confirmed this.
Check out my photos at http://dkoretz.smugmug​.com (external link)
jeroenw
Gallery: 22 photos
Aug 02, 2012 06:59 |  #7
I believe you're right about that. The IS works for about 1 stop because it can compensate for linear movement (left/right up/down) but since it can't compensate for front/back movement which also causes big problems in macro shots, the advantage you gain with the IS is limited.
Earwax69
Joined Jul 2012
Aug 02, 2012 07:33 |  #8
Mmm... thanks Paddler4. And what is your verdict? Is paying double for IS worth it? Do you think you get a lot more usable pictures compare to when the IS is off?
I'm starting to regret having picked the Tamron 90mm. It's stellar but for 100$ more I could have the Sigma with image stabilisation. I do my best handheld but only 20% of my pics are usable due to motion blur.
LeeRatters
Aug 02, 2012 10:16 |  #9
Earwax69 wrote in post #14803833 (external link)
Motion blur or camera shake?
>> Flickr << (external link)
>> Instagram<< (external link)
prustyaditya
Joined Aug 2012
Aug 02, 2012 10:23 |  #10
I would think because you tend to do macro photography with a tripod ? Well i do anyway
hi.
Apricane
Shooting the breeze
Gallery: 93 photos
Joined Nov 2011
Aug 02, 2012 11:25 |  #11
Well it's not always possible to have a tripod when doing macro shots, as in a museum for instance, or when doing shots in other crowded places.
Apricane flickr (external link) IG Travel/Street (external link)
a7 IV | Ʃ 35+85/1.4 Art | SY 135/1.8 | Tmr 28-200 | Tmr 70-180/2.8 | Sony 70-350G
X-T30 | XF18-55 | XF16-80 | Ʃ 56/1.4
Capture One 23 Pro | Affinity Photo
paddler4
Aug 02, 2012 12:15 |  #12
it's not an easy call, but I think it was for me. I do quite a bit of handheld macro work, and for that, the hybrid IS is worth perhaps 1.5 stops. It's also nice to have the regular IS if you want to use the lens as a telephoto. If you switch on the focus limiter, it makes a superb telephoto. however, for macro work on a tripod or using flash to stop motion, there would be no value. And it does nothing to help you nail focus, which is a huge problem with handheld macro work.
I'm not certain, but I doubt the sigma has a form of IS useful at macro distances. if it is their conventional OS, it would not be, I think.
maverick75
Joined May 2012
Aug 02, 2012 12:20 |  #13
You need to learn how to hold a camera. I can do 1/10 handheld no problem with 80% usable images.
You're only getting 20%?
Tuck your elbows to your body to stabilize your camera more.
Eyal
Joined May 2011
Aug 02, 2012 13:23 |  #14
If you only want it for IS, than no, not really.
But the L lens is not only about the IS. There is the build quality and the weather protection. Its designed so that you can use it in a dump area for example, a bit of rain fall, and capture your image with less worries.
Also about blur, most likely learning to hold a heavy camera setup is in need. I usually use mine hand help with a flash, and after awhile its getting easier to find your way.
Techuser
Aug 02, 2012 13:30 |  #15
maverick75 wrote in post #14804924 (external link)
At 1:1 on a 100mm, no you can't.
Canon XSi | 18-55 IS | 50 1.8 | 70-300 IS | 300 2.8 FD
http://primalshutter.c​om (external link)
7,031 views & 0 likes for this thread, 20 members have posted to it.
2695 guests, 149 members online
