Thread started 02 Aug 2012 (Thursday) 12:18
I own two 430 EX II flashes and have $49.43 in Ebay Bucks. What do I do with it?
TheRightLight
Joined Apr 2012
Aug 02, 2012 12:18 |  #1
As the title suggests, I only own two 430 EX II flashes. I have no stands, triggers, or umbrellas, which is obviously a problem.
With $49.43 in free cash, where should I allocate my funds? Any suggestions? I have 13 hours from the time of this post...  :p
(Note: I'm willing to spend more than $49.43, but I'd like to keep things under $100 if possible. Also: I own a 60D, which means I can use optical triggering...)
Marketplace Feedback:
As a Seller: One. Two. Three. As a Buyer: Link.
My Ebay Account: 100% Positive Feedback. (external link)
KirkS518
Joined Apr 2012
Aug 02, 2012 14:13 |  #2
Radio triggers
Flash Bracket
Set of gels
Light stand
Softbox
Memory
Light meter
Nifty Fifty
Grip
Just some of what I would look for or already have....
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
HughR
Aug 02, 2012 17:13 |  #3
You're right, the wireless pop-up control on the 60D works very well at the distances Canon specifies. Therefore, the obvious things are light stands and softboxes. the Lumiquest Softbox III does a fairly good job and is around $45. The Cheetah Qbox 16x16 is about $90 but a good investment. My light stands were under $30 each for 7' height. Quite adequate for my 430EXs with softbox attached.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
whuband
Aug 02, 2012 21:06 |  #4
Light stands and umbrella brackets and an inexpensive umbrella. Probably a reflector or maybe a softbox next.
1D4, 6D, 7D2, Sony a6000 with Sony16-70, Rokinon 12mmf2, Canon lenses: 17-40L, 17-55 f2.8, 10-22, 50mm 1.4, 85mm 1.8, 70-200mm IS 2.8, 300mm 2.8 IS, 580EXII (3), 430EX, Alien Bees.
TheRightLight
Joined Apr 2012
Aug 02, 2012 23:22 |  #5
What do you guys think of this? I've got under 2 hours left...
http://www.ebay.com …ain_0&hash=item​20c6d99d95 (external link)
SMP_Homer
Gallery: 29 photos
Aug 02, 2012 23:33 |  #6
Wouldn't a softbox interfere with the whole line of sight thing?
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
TheRightLight
Joined Apr 2012
Aug 03, 2012 01:19 |  #7
I went for a 50mm 1.8 Mark II lens for a grand total of $50 shipped.
I haven't decided whether or not I'm going to keep it or sell it for profit, but either way, I thought that was a better option than rushing into a lighting kit decision with absolutely NO knowledge whatsoever on brand quality, umbrella styles, etc.
TheRightLight
Joined Apr 2012
Aug 03, 2012 01:21 |  #8
That being said, I should probably be doing some research now so I don't have to "waste" my Ebay bucks ever again. :-D
HughR
Aug 03, 2012 11:42 |  #9
SMP_Homer wrote in post #14807597 (external link)
No. All you have to do is rotate the flash body relative to the head so that the flash is pointed into the softbox and the sensor on the body is pointed toward the pop-up or towards a reflective surface that will bounce the pop-up signal. Works great.
Hugh
bebud
Aug 04, 2012 20:20 as a reply to  @ HughR's post |  #10
Adorama sells on ebay. They have several strobist kits under $100. I just bought the two umbrella flashpoint kit...just a suggestion...
7d ,6d,10-22,70-200 f4, 24 f2 is,Tamron 28-75 f2.8, Tamron 90mm macro,Tamron 18-270
simplydave.net (external link)
Tiberius
Aug 04, 2012 20:23 |  #11
Not really. I use the Canon optical triggering system with an Ezybox and it works fine.
My photography website!PHOCAL PHOTOGRAPHY (external link)
2,299 views & 0 likes for this thread, 7 members have posted to it.
Latest registered member is Tacbeardpics
497 guests, 208 members online
