Does the 100-400mm lens fit the canon 450d? also what about the 70-200mm?
HeycoopPhotography Senior Member 507 posts Likes: 1 Joined May 2012 Location: New Zealand More info | Aug 03, 2012 00:14 | #1 Does the 100-400mm lens fit the canon 450d? also what about the 70-200mm? Body: Canon 450D Gripped
rrblint Listen! .... do you smell something? More info | Aug 03, 2012 00:16 | #3 If you are refering to Canon EF lenses...Then yes. Mark
HeycoopPhotography THREAD STARTER Senior Member 507 posts Likes: 1 Joined May 2012 Location: New Zealand More info | Aug 03, 2012 00:27 | #4 rrblint wrote in post #14807754 If you are refering to Canon EF lenses...Then yes. Ok thanks, what is the difference between EF and EF-S lenses? You can obviously tell i'm an amateur! Body: Canon 450D Gripped
Nightdiver13 Unabashed nerd! 2,272 posts Likes: 38 Joined May 2010 Location: Bigfoot Country More info | Aug 03, 2012 00:32 | #5 EF-S lenses will only work on 1.6x crop bodies (maybe excluding the 10D?), where as EF lenses will work on any Canon dslr including 1.6x, 1.3x and full frame bodies. — Neil
1Tanker Goldmember 4,470 posts Likes: 8 Joined Jan 2011 Location: Swaying to the Symphony of Destruction More info | Aug 03, 2012 00:38 | #6 Nightdiver13 wrote in post #14807791 EF-S lenses will only work on 1.6x crop bodies (maybe excluding the 10D?), where as EF lenses will work on any Canon dslr including 1.6x, 1.3x and full frame bodies. ^Yes. Kel
prustyaditya Member 55 posts Joined Aug 2012 More info | Aug 03, 2012 04:09 | #8 The 100-400 is an EF lens, so it will fit all EOS cameras. The same goes for the 70-200. hi.
Aug 03, 2012 04:15 | #9 CaterhamF1 wrote in post #14807776 Ok thanks, what is the difference between EF and EF-S lenses? You can obviously tell i'm an amateur!
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | prustyaditya wrote in post #14808221 Just keep in mind, with a 450d , the 100-400 will be a 160-640mm lens because of the crop sensor. The 70-200 will be a 112 - 320 lens The 100-400 will NOT be 160-640, and the 70-200 will NOT be a 112-320. Lens focal length is inherent, and does not alter with body format.
Aug 03, 2012 07:31 | #11 prustyaditya wrote in post #14808221 Just keep in mind, with a 450d , the 100-400 will be a 160-640mm lens because of the crop sensor. The 70-200 will be a 112 - 320 lens It does not work that way. 50mm is 50mm on both "cropped" and "full frame" bodies. A 100-400 and 70-200 will still be a 100-400 and 70-200 on a 450D.
MotorPro Member 30 posts Joined Jun 2012 More info | Aug 03, 2012 12:29 | #12 prustyaditya wrote in post #14808221 The 100-400 is an EF lens, so it will fit all EOS cameras. The same goes for the 70-200. Just keep in mind, with a 450d , the 100-400 will be a 160-640mm lens because of the crop sensor. The 70-200 will be a 112 - 320 lens Here we go again
Aug 03, 2012 12:41 | #13 Some how we went from will these lenses fit to the focal length debate again. Cameras: 7D2, S100
BigSky Senior Member 745 posts Joined Feb 2007 Location: Billings, Montana More info | Aug 03, 2012 14:18 | #14 prustyaditya wrote in post #14808221 Just keep in mind, with a 450d , the 100-400 will be a 160-640mm lens because of the crop sensor. The 70-200 will be a 112 - 320 lens No they won't.
BigSky Senior Member 745 posts Joined Feb 2007 Location: Billings, Montana More info | Aug 03, 2012 14:18 | #15 Guess I should have looked at other replies first.
| Latest registered member was a spammer, and banned as such! 2762 guests, 151 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
