Thread started 18 Dec 2005 (Sunday) 16:22
wide angle need advice here
MJP
Dec 18, 2005 16:22 |  #1
im looking for a little bit kind of wide angle lens here...im looking at the sigma 18-50mm F2.8 EX DC or the 10-20mm F4-5.6 EX DC HSM but my first choice is the canon 16-35L...need to know any suggestions?....thanks​...
:grin:MarkIIN,5D w/ grip,PS SD10
70-200mm f/2.8IS Canon 1.4X II|sigma 12-24mm
| EF85mm f/1.8|Ef 24-105mmL | 100mm macro| RS-80N3 | MinoltaAutometer|I9900|CS2|LR|CS3| Angle Finder
Manf 190MF4 tripod, 680 mono, 322RC2 Joystick Head |
580EXII,580EX,430EX,ST​-E2,CP-E3
www.pbase.com/marlonjp (external link)
gasrocks
Dec 18, 2005 17:25 |  #2
Your signature is confusing. What body? You have a 24-70? Then get the 10-22 efs?
Carzee
Dec 18, 2005 17:30 |  #3
Try the 14mm (22mm on the 20D), various brands. I am liking it a lot!
samples http://www.pbase.com/p​ixelparker/toy_run_200​5 (external link)
Having a bad day? Feeling down? Bantar Gebang Attitude Enhancement Images (external link)
jojohohanon
Dec 18, 2005 18:59 |  #4
That's a huge range of variation!
one of your examples is 18mm, the other is 10mm: that's almost twice the field of view! Perennial favorites are the Canon 10-22 and the tokina 12-24. If you can find the 10-22 for $650ish, go for the canon, else give the tokina a good home. Either will make you very happy. I can vouch for the canon, and I've heard enough good things about the tokina from others to believe 'em, collectively.
Of course, if you want constant 2.8, there are many fewer options open to you.
trivial
Dec 18, 2005 19:32 as a reply to  @ jojohohanon's post |  #5
He has the 1Dmk2N... I don't think that the canon 10-22 will work with it.
... but what do I know.
-Matt
20D
17-40 f/4L
70-200 f/4L
50 f/1.4
MJP
Dec 18, 2005 19:49 as a reply to  @ trivial's post |  #6
-Matt
yeah u r right, its not gonna work...its an EFS lens...anyway i just need an wide angle lens...
ddelallata
Dec 18, 2005 20:04 as a reply to  @ MJP's post |  #7
Get the Canon 17-40 f/4 of the Canon 16-35 f/2.8. It sounds like you can afford either one.
Dr. David de la Llata
_____________
Canon 20D
BG-E2 Battery Grip
Canon SpeedLite 430 EX
Canon EF 1.4X II
Canon EF-S 10-22mm F/3.5-4.5 USM
Canon EF 50mm F/1.4 USM
Canon EF 100mm F/2.8 MACRO USM
Canon EF 24-70mm F/2.8 L USM
Canon EF 70-200mm F/2.8 L USM
Olympus C-2020 (for infrared work)
DocendoDiscimus
Dec 19, 2005 05:24 |  #8
If you just want a wider lense than the Sigma 24-70mm, why don't you consider a prime like the Sigma 20mm 1.8 EX DG?
Jon
Joined Jun 2004
Dec 19, 2005 11:52 |  #9
Can't use the Sigma 18-50 or 10-20 you posted either. The DC lenses won't cover larger than the APS-C format. You'd get dark corners (like no image). Your options are the 16-35 L, the 17-40 L, the Sigma 12-24, Sigma 15-30, and the Tamron 17-35, IIRC.
Jon
Cocker Spaniels
malla1962
Joined Jul 2004
Dec 19, 2005 12:16 as a reply to  @ Jon's post |  #10
The 17-40 works very well on a 1.3 crop body.:D
Longwatcher
obsolete as of this post
Joined Sep 2002
Dec 19, 2005 13:37 as a reply to  @ malla1962's post |  #11
If you don;t need that little bit of aperture then the 17-40 will do you good, but if you need that extra f-stop definately go for the 16-35/2.8L. I have the 16-35 and it takes great pictures. The sigma 12-24 is the only lens that might possibly be a better choice (only because it is wider)
Just my opinion,
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
Tapeman
Sliced Bread
Joined Jan 2004
Dec 19, 2005 14:21 as a reply to  @ Longwatcher's post |  #12
After long consideration I chose the 16-35L over the 17-40L and am sure I made the right decision. I think that the lens works best on a body with a bright viewfinder.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
MJP
Dec 19, 2005 22:07 |  #13
thanks for your advice guys....i will consider 16-35L (xbox 360 has to wait for a while) or the sigma 12-24.....
2,043 views & 0 likes for this thread, 11 members have posted to it.
2173 guests, 129 members online
