Thread started 04 Aug 2012 (Saturday) 10:27
Anything like the radiopopper that works?
bigVinnie
Aug 04, 2012 10:27 |  #1
My needs are simple.
I want to manually control power output on small strobes without having to be an acrobat.
Everything I've looked at seems to be setup for e-ttl use. Fine and dandy but to me it takes too much time to dink around with that. If I need a 1 stop change to a light I want to just move a slide or turn a knob. Same thing I've been doing for 30 years.
What I REALLY want is something like the Paul C. Buff LG4X that works wirelessly with canon flashes. Does anyone make something like that?
I did try the radiopopper setup. My RF-602's are more reliable.
Act1 Photo Booths (external link)
ku8843
Joined Jan 2012
Aug 04, 2012 10:49 |  #2
If just for Canon flashes the Pixel Kings should do it for you.
You can control the flash from the camera and change the flash settings how you please. This works best for manual on the flashes. If you did want ETTL then you can only adjust plus or minus FEC I believe.
5D III | 70D | 15-30 2.8 VC | 24-70 2.8 VC | 70-200mm 2.8 IS II | Σ 35mm 1.4 | 85mm 1.8 | 100mm 2.8 IS | 1.4x Extender II | 2x Extender III | Kenko Extension Tubes | 580EXII | YN565 | Einstein640 (x3)
http://www.scottpeters​onphoto.com (external link)
http://www.facebook.co​m/ScottPetersonPhoto (external link)
ku8843
Joined Jan 2012
Aug 04, 2012 10:50 as a reply to  @ ku8843's post |  #3
Never mind. Just realized that you didn't want these for Canon flashes.
Stuperfox
Gallery: 12 photos
Aug 04, 2012 10:52 |  #4
All of the strobe control sets are not really that reliable(for small strobes, for larger studio lights they work amazingly).
The Pocket Wizard system with the AC3 zone controller is exactly what you want. But out of the 10 people that I know that own them, none of them use them for lack of reliability. They work amazing when you are trying to play around but the second you need them to work for real, they dont and are all kinds of messed up.
You can use canon's IR wireless to get the same control with the lack of reliability outside and it is line of sight.
To be honest Canon's 600EX RT is what you want in the end, it is all the advantages of the canon wireless(control of all aspects of the flash such as power, exposure compensation, zoom setting, high speed sync) with the reliaiblty.
Though you have to replace your entire set up for that and if you are doing a 3 flash setup it will be almost $1800 for the flashes and trigger.
At that point you might as well get a few AB400 flashes and vagabond minis with a cyber commander, which funny enough will give you an 2 stop of power and cost about $500 less for the same three light setup.
Nick
"I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
EOS R6 MK II Gripped | EOS R6 | 24mm F1.4 | 35mm F1.8 IS | 50mm F1.8 | 135mm F2L | 15-35mm F2.8L IS | 24-70mm F2.8 II | 70-200mm F2.8L IS | 150-600mm F5-6.3 G2
dmward
Gallery: 29 photos
Aug 04, 2012 10:53 |  #5
Pocket Wizard ControlTL makes it possible to do manual adjustments over a 6 stop range with manual control using the AC3 on top of the camera. The speedlites are ETTL on the FlexTT5. That's so they will accept the commands via the ControlTL stuff.
SMP_Homer
Gallery: 29 photos
Aug 04, 2012 12:06 |  #6
I use TT1 and TT5 units to control flashes and strobes. The AC3 allows me to vary settings, or disable them totally, from the camera position.
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
elv
Aug 04, 2012 12:14 |  #7
The Fox wrote in post #14813346 (external link)
The Phottix Odins are brilliant with speedlites, in manual and/or ETTL.
FLASHHAVOC.COM (external link)
butterfly2937
Gallery: 378 photos
Aug 04, 2012 13:48 as a reply to  @ dmward's post |  #8
What about phottix odin? It does manual and ETTL and is very reliable.
GEAR
SMP_Homer
Gallery: 29 photos
Aug 04, 2012 14:11 |  #9
butterfly2937 wrote in post #14813928 (external link)
does it allow to change/control remote strobe power from the camera? Totally not familiar with that one
bigVinnie
Aug 04, 2012 14:46 as a reply to  @ SMP_Homer's post |  #10
I do realize that i need to switch to cannon flashes.
So the Odin system will allow me to use the canon or yonguo flashes on manual power and turn them up and down without a bunch of menus to scroll through?
The Canon 600 flash is not what I'm looking for. Way too much. For my budget. I can get 2 yn flashes and the odin receivers for less than one of those costs. Like I stated the ettl does not interest me. Just call me an old fart about that.
I will see ifI can find the manual for the Odin and check it out.
butterfly2937
Gallery: 378 photos
Aug 04, 2012 15:03 |  #11
SMP_Homer wrote in post #14813980 (external link)
Yes if you are using cannon flashes plus supports M and ETTL plus zooms the flash head all from the transmitter on the camera. Really simple to use and you can have groups in both M and ETTL. They are fabulous. Plus supports HSS.
GEAR
bigVinnie
Aug 04, 2012 15:23 |  #12
Just read the manual. Pretty cool system. Looks like it is the one I'm looking for.
Hate to retire the trusty 285 flashes, but time to upgrade.
butterfly2937
Gallery: 378 photos
Aug 04, 2012 15:34 |  #13
bigVinnie wrote in post #14814160 (external link)
Very easy to use and it has been 100 % reliable for me. It is much quicker and easier than scrolling through camera menus.
GEAR
bigVinnie
Aug 04, 2012 16:47 |  #14
From what I'm finding online it look like the Odin is not compatible with the YN flashes. Can someone confirm this?
Not really a deal breaker for me, just means I have to spend a few more bucks.
butterfly2937
Gallery: 378 photos
Aug 04, 2012 19:10 |  #15
bigVinnie wrote in post #14814416 (external link)
Info here: http://www.flickr.com …iscuss/72157628​093126883/ (external link)
GEAR
2,596 views & 0 likes for this thread, 7 members have posted to it.
1076 guests, 113 members online
