Can anyone tell me plz
is the canon extender x1.4 work fine auto focus with this lens on the 7D ?
or it will be manual focus ?
i want to know before buying this extender
moltengold Goldmember 4,296 posts Likes: 10 Joined Jul 2011 More info | Aug 04, 2012 10:42 | #1 Can anyone tell me plz | Canon EOS | and some canon lenses
Aug 04, 2012 10:48 | #2 It should be manual only, on the long end. I believe only the 1D series is capable of AF on f8 which is the f-stop you would be with the 100400 + 1.4 TC. I have read that some of the sigma TC will allow AF in bright conditions, but not reliably. Feed back #1#2
Aug 04, 2012 11:05 | #3 Thanks a lot | Canon EOS | and some canon lenses
inernets Senior Member 598 posts Joined Dec 2007 Location: D.C. More info | you can use the tape trick to gain auto focus. You can read more from the link below, there is also a link to a website (bottom of post) that shows you how to do it. Canon 100-400mm L + 1.4x III Extender - 100 vs 400 Here is a link to the tape trick: http://www.michaelfurtman.com/taping_the_pins.htm I have used the 5D II + tape trick on extender + 100-400mm with some great results. You need a lot of light for the auto focus to work well. You can read the flickr review above for more info on that. If you do do the tape trick, be careful because if you keep your lens in a very hot place for long periods of time (like your car on hot summer days) the tape can stick to your lens mount and it can be difficult to remove. If this happens you will have to clean the contact points where the tape was, no big deal. If you want i can show pictures of 100-400mm with extender 1D III - 1D II - 5D II - 50D - 40D - EOS M.
Aug 04, 2012 15:25 | #5 Thanks internets | Canon EOS | and some canon lenses
wayne.robbins Goldmember 2,062 posts Joined Nov 2010 More info | Aug 04, 2012 21:22 | #6 I don't have a 100-400L. While using a 1.4x TC with it should make AF not work- and you might be able to pull off autofocus with the tape trick- there are other tricks that can help. EOS 5D III, EOS 7D,EOS Rebel T4i, Canon 70-200 f/2.8 IS II, Canon 24-105L, Canon 18-135 IS STM, 1.4x TC III, 2.0x TC III, Σ 50mm f/1.4, Σ 17-50 OS, Σ 70-200 OS, Σ 50-500 OS, Σ 1.4x TC, Σ 2.0x TC, 580EXII(3), Canon SX-40, Canon S100
1Tanker Goldmember 4,470 posts Likes: 8 Joined Jan 2011 Location: Swaying to the Symphony of Destruction More info | It blows my mind, how many people are too lazy too search anything. Although the search on this site is pretty lame, there are 100's of threads regarding this, filters, 50/1.8 vs 50/1.4, 24-105 vs. 24-70, etc. etc. Kel
Skul Member 92 posts Likes: 2 Joined Oct 2011 Location: SE Texas More info | Aug 05, 2012 07:28 | #8 I, also use the tape trick with a 5D Mkll. It works, and as mentioned by others, slow.
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Aug 05, 2012 09:02 | #9 Same here, the tape trick does the business. I don't find it slow in shady conditions, it just keeps going. Richard
modchild Goldmember 1,469 posts Likes: 3 Joined Jul 2011 Location: Lincoln, Uk More info | Aug 05, 2012 16:30 | #10 I've used my Kenko Pro300 DGX 1.4x converter on a Canon 100-400 L and retained AF on my 550D, 60D, 7D, 5D2 and 5D3. The DGX version doesn't need any pins taping and it reports correctly in the EXIF too. It slowed down the AF very slightly and it AF'd in all but dull light and there was negligable loss in IQ too. EOS 5D MkIII, EOS 70D, EOS 650D, EOS M, Canon 24-70 f2.8L MkII, Canon 70-200 f2.8L IS MkII, Canon 100 f2.8L Macro, Canon 17-40 f4L IS, Canon 24-105 f4L IS, Canon 300 f4L IS, Canon 85 f1.8, Canon 50 f1.4, Canon 40 f2.8 STM, Canon 35 f2, Sigma 150-500 OS, Tamron 18-270 PZD, Tamron 28-300 VC, 580EX II Flash, Nissin Di866 MkII Flash, Sigma EM 140 Macro Flash and other bits.
gocolts Goldmember 1,246 posts Likes: 14 Joined Oct 2010 More info | Aug 05, 2012 21:20 | #11 modchild wrote in post #14818085 I've used my Kenko Pro300 DGX 1.4x converter on a Canon 100-400 L and retained AF on my 550D, 60D, 7D, 5D2 and 5D3. The DGX version doesn't need any pins taping and it reports correctly in the EXIF too. It slowed down the AF very slightly and it AF'd in all but dull light and there was negligable loss in IQ too. Good to hear- yours is one of the most positive reports on this. My Canon 400mm f/5.6L was pretty good with that Kenko TC, I am hesitant to push my luck on a 100-400L, but it sounds like I should maybe give it a shot with my 7D.
| Latest registered member is semonsters 1468 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
