Thread started 18 Dec 2005 (Sunday) 19:05
Canon 10-22mm on a 1D Mark II Body?
PaintballPhotography.com
Dec 18, 2005 19:05 |  #1
I am considering buying the Canon 10-22mm f/3.5-4.5 USM EF-S lens. According to Canon this lens is intended for the 20D and the Digital Rebel but can it be used on a 1D Mark II body?
I currently use a 20D and 1D Mark II body and I have used my existing lenses on both bodies with out any problems. Does the Canon 10-22mm have something that prevents it from being used on the 1D Mark II body?
As always Thanks!
Gary Baum
www.paintballphotograp​hy.com (external link)
NPPL 2009 Photographer of the Year
NXL Media Liaison
SportsShooter Member
Todd ­ Jacobsen
Dec 18, 2005 19:11 |  #2
No, it cannot be used. The lens extends into the camera body farther than the regular EF line. If Canon was smart, they would produce an extension for regular camera body lines...
But then again. they'd have to be committed to the EF-S line...
Todd Jacobsen
20D / Rebel T2
EF : 28 f1.8/ 50 f1.4/ 50 f2.5 Macro/ 85 f1.8/ 20-35 f3.5-4.5 USM
EF-L: 16-35 f2.8/ 24-70 f2.8/ 70-200 IS f2.8 / 100-400 IS f4.5 / 180 f3.5 Macro
EF-S: 10-22 f3.5-4.5 USM
ddelallata
Dec 18, 2005 19:13 |  #3
The only way you can get it to fit would be with an ET-12 II (Canon extenion tube), but your maximum focusing distance would be very limited.
Dr. David de la Llata
_____________
Canon 20D
BG-E2 Battery Grip
Canon SpeedLite 430 EX
Canon EF 1.4X II
Canon EF-S 10-22mm F/3.5-4.5 USM
Canon EF 50mm F/1.4 USM
Canon EF 100mm F/2.8 MACRO USM
Canon EF 24-70mm F/2.8 L USM
Canon EF 70-200mm F/2.8 L USM
Olympus C-2020 (for infrared work)
cosworth
I'm comfortable with my masculinity
Dec 18, 2005 19:17 |  #4
You can machine it just like people machine the kit lens to fit. You essentially screw up an expensive lens and it will take more $$$ to make it fit.
Certainly not worth it.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
grego
Dec 18, 2005 19:19 |  #5
The 10-22 on a 1.6 crop is like a 16mm lens.
The 16-35 or 17-40 would be your best bets if you are going to use that camera.
Go UCLA (external link)!! |Gear|http://gregburmann.com (external link)SportsShooter (external link)|Flickr (external link)|
ddelallata
Dec 18, 2005 19:49 as a reply to  @ grego's post |  #6
Not on his camera. With the 1.3X crop factor of the 1D m II this lens would be the equivalent of 13mm at the wide end.
_____________
Canon 20D
BG-E2 Battery Grip
Canon EF 1.4X II
bolantej
Dec 18, 2005 20:51 |  #7
either way i think it would be silly to get it and hack it. just get a lens that works from teh start so there's less chance of things gettign screwed up.
tim
Light Bringer
Dec 18, 2005 21:05 |  #8
No, it won't work, get an EF lens not an EF-S lens.
MrChad
Joined Aug 2004
Dec 18, 2005 21:16 as a reply to  @ tim's post |  #9
Well if you'd be happy using it on the 20D only it's still a nice lens, for as often as I use a wide anlge, I could leave mine on the Drebel full time if I had a 1D.
I kaNt sPeL...
[Gear List]
farrukh
Dec 19, 2005 02:22 as a reply to  @ MrChad's post |  #10
EF-S are only for 1.6x bodies.
Sigma 12-24EX is the only lens that fits on any body.
5D Mark II + 40D | Lenses: Sigma 150-500mm BigmOS / Canon 24-105mm F4L IS / Canon 70-200 F4L IS / Canon 85mm 1.8 / Sigma Macro 70mm f/2.8 EX / Sigma 10-20mm EX / Canon 50mm f/1.8 II / Sigma 1.4x APO TC / Kenko 2x PRO300 DG. Lighting: Canon 580EX II + Metz 58 AF-1 + Sunpak 383...
Jman13
Dec 19, 2005 03:11 |  #11
Well, the Tokina 12-24 will fit on any body, and it will work on a 1.3x, but will vignette until about 15mm, where it then becomes usable. It will also work on a full frame body, but only from about 17mm on.
Farrukh is right about the 12-24 being the only really wide lens that is truly usable (and still wide) on any body, with full focal length coverage.
Jordan Steele - http://www.jsteelephot​os.com (external link) | https://www.admiringli​ght.com (external link)
Canon EOS R5 | R6 | TTArtisan 11mm Fisheye | Sigma 14-24mm f/2.8 | RF 24-105mm f/4L IS | Tamron 35mm f/1.4 | RF 35mm f/1.8 | RF 50mm f/1.8 | RF 85mm f/2 | RF 70-200mm f/2.8L IS | Sigma 135mm f/1.8
StealthLude
Dec 20, 2005 02:26 |  #12
not going to work..... Why even try it?
Get a 17-40L, its the SAME THING
[[Gear List]]
Skype: Stealthlude
grego
Dec 20, 2005 02:50 as a reply to  @ ddelallata's post |  #13
The lens won't even work on there. With the 1.3 crop, on a 16mm focal length from the 16-35, you still get a very wide angle lens.
2,132 views & 0 likes for this thread, 11 members have posted to it.
2173 guests, 130 members online
