Thread started 05 Aug 2012 (Sunday) 16:35
What lens I need to take detailed photos of lashes?
LittleMole
Joined Aug 2012
Aug 05, 2012 16:35 |  #1
I want to make macro photos of lashes like this:
IMAGE: http://s3.favim.com/orig/46/clear-eye-girl-lashes-macro-Favim.com-430347.jpg
Now i have good offer for 100mm macro lens, that can focus from 40 cm. Would it be sufficient or i need lens that can focus closer for pictures like that? I'm using fullframe camera.
Randi
Aug 05, 2012 16:41 |  #2
Per the EXIF, that photo was taken with an 100mm f/2.8.
LittleMole
Joined Aug 2012
Aug 05, 2012 16:51 |  #3
Yes, but it was taken by 500D that is not fullframe, so there is crop-factor and I'm not sure, if I can make the same photo with fullframe camera, if that lens allow you to go closer.
Hermes
Aug 05, 2012 16:55 |  #4
That can be done with a 100mm macro, any other true macro lens or a decent quality prime lens (85mm.1.8 for example) and a full set of Kenko extension tubes.
Winwin
Joined Mar 2011
Aug 05, 2012 16:56 |  #5
100mm Macro, 60mm Macro, Or a lens with extention tubes.
Win.
Canon 5D Mark III, 100 f/2.8L Macro, 50 f/1.8 STM
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Aug 05, 2012 16:57 |  #6
The " crop factor" has zero bearing on what you are talking about; yes, the 100mm macro will do shots like that for you.
Madweasel
Aug 05, 2012 16:58 |  #7
It would still be possible on FF, but you would be nearer to the minimum focusing distance. The 100/2.8 macro will allow you to go to 1:1 reproduction at the sensor, so the full field at 1:1 will be 24mm x 36mm on FF. Plus, you can always crop it a bit more afterwards.
Mark.
LittleMole
Joined Aug 2012
Aug 05, 2012 17:02 |  #8
But lens that I'm about to buy can focus from 40 cm, not from 30 cm like Canon EF 100mm f/2,8 Macro. Will it be a problem?
sploo
premature adulation
Joined Nov 2011
Aug 05, 2012 17:26 |  #9
LittleMole wrote in post #14818192 (external link)
The important question isn't as to how close a lens can focus, but its maximum magnification ratio.
For instance, a Canon APS-C body (22.2mm wide sensor) with a 15-85 lens (which has a MM ratio of 0.21) should be able to focus on something that's 22.2mm/0.21=105.7mm wide. Indeed, if I lay a rule down on a table and try to focus on it, that's about as much magnification as I can get. With a macro lens (that has a 1:1 reproduction - i.e. 1.00 MM ratio) you can photograph something that's 22.2/1.00=22.2mm wide.
Think of your minimum focusing distance as your working distance. A 100mm macro lens that claims 1:1 will have a closer minimum focussing distance than a 180mm macro lens that is 1:1. Because 180mm is more telephoto, it can still give you 1:1 reproduction, but doesn't need to get as close. So, the longer focal length lens gives you more effective working distance, whilst still giving 1:1 reproduction.
You mention you have an offer for a 100mm macro lens. If it's a true macro lens (i.e. 1:1 reproduction), and its minimum focussing distance is 40cm, then you can assume it'll give you 1:1 at 40cm. As you have a FF body, that means an object around 36mm wide will fill the frame width. That should be pretty much spot on to take a shot of an adult's eye that completely covers the frame.
Camera, some lenses, too little time, too little talent
LittleMole
Joined Aug 2012
Aug 05, 2012 17:42 |  #10
Yeah, I finally understand it. Tomorrow i will buy that 100mm lens. Thank you all guys (especially sploo)!!
snake0ape
Aug 06, 2012 01:47 |  #11
LittleMole wrote in post #14818154 (external link)
I think some one says you can get close enough with FF.
What needs to be considered here is the DOF. The crop camera will get you a much deeper DOF given the same F-stop and with intent to filling the frame with the eye. Looks like about a 1/2 inch "in focus" depth on the picture. If you have a full frame, you will be getting about 1/4 inch "in focus" or will need to change to a higher f-stop... maybe a 1.5 stop difference.
5Diii | 50D | 8-15L 4| 16-35L 2.8 II| 24-70L 2.8 II | 70-200L 2.8 IS II |Tamy 150-600 | Σ35Art 1.4 | 40 2.8 | Σ50Art 1.4 | 85L 1.2 II | 100 2.8 Macro | Helios 44-3 58mm f2.0 |Helios 40-1 85mm f1.5 | 1.4x & 2x teleconverters
Lowner
"I'm the original idiot"
Aug 06, 2012 02:36 |  #12
I am told that all macro lenses will do 1:1 (lifesize), its only the field of view that varies and that really only affects backgrounds. How true that is I'm not thr right person to judge.
Naturally I'd go for a longer focal length macro so I was shooting from slightly further away.
As snake0ape says, DoF is the big problem, no matter which lens it is. f/16 is really the limit, any wider and DoF is so thin as to be non existant.
Richard
sploo
premature adulation
Joined Nov 2011
Aug 06, 2012 03:22 |  #13
LittleMole wrote in post #14818311 (external link)
You're welcome :)
snake0ape wrote in post #14819913 (external link)
...What needs to be considered here is the DOF...
Using http://www.dofmaster.c​om/dofjs.html (external link) I see that a 7D with a 100mm lens at f8 and 40cm distance to subject gives about 0.36cm of DOF. The same details for a 5D give 0.58cm DOF. I suspect the fact that the 100mm lens on the 7D gives the same fov as a 160mm has a bearing on the apparent DOF.
Remember though that DOF is very theoretical, and based on acceptable sharpness for a certain sized print viewed at a certain distance by a person with good eyesight (can't remember the defaults off the top of my head). If you were planning on printing huge, then you'd need more DOF to maintain apparent sharpness.
Lowner wrote in post #14819992 (external link)
I think there are some 50mm 'macro' lenses that are actually only 1:2 (i.e. half life sized). But, with pretty much any lens you can add extension tubes to reduce the minimum focussing distance and thus increasing magnification. As you say, the longer focal lengths allow more distance to the subject, so I'd expect a 50mm 1:2 macro with enough extension to get to 1:1 may have very little working room.
Lowner
Aug 06, 2012 05:53 |  #14
sploo wrote in post #14820053 (external link)
That may be true with normal images, but my admittedly limited macro experience is that once outside that DoF, the blurring is immediate and pretty total. And we also know everyone peers closely at interesting images.
Richard
sploo
premature adulation
Joined Nov 2011
Aug 06, 2012 07:37 |  #15
Lowner wrote in post #14820273 (external link)
I think the issue is that "that DoF" is the depth that's considered to be acceptably in focus (so, yes, anything outside the DOF region would be soft). I don't know how the sharpness falls off as you move away from the focus point though (whether it's linear or some form of bell curve) - or even if it changes shape depending on the focus distance.
I do understand that when you get very close (focussing distance) the DOF and hyperfocal distance calculations tend to go "a bit weird". I guess with such shallow DOF at macro distances it's going to drop away quickly (i.e. a very steep curve from out-of-focus to in focus to out-of-focus).
What I meant by apparent DOF is that it's all down to circle of confusion calculations; and stricter values would need to be applied when printing larger, which has the effect of making your acceptable DOF shallower. Therefore if printing very large it may be necessary to stop down further - though I guess that at some point diffraction softness sets in and robs the whole image of sharpness. That's why the landscape pros love tilt/shift lenses, as they can control the plane of focus to squeeze out more usable DOF without stopping down into the diffraction region.
5,270 views & 0 likes for this thread, 9 members have posted to it.
2762 guests, 151 members online
