Hey guys,
I will start by saying this post is primarily dedicated to wedding photography using an on camera flash AND triggering off camera flashes. I currently am using a 580 on camera and YN560s off camera for reception hall lighting. In a perfect world I'd be able to use the 580 in ETTL and the 560's on manual (duh) and trigger all 3 at the same time. Right now I am running modified pt-04 triggers (which have some range, but every so often aren't consistent). I"m looking for a more consistent setup.
Yes, it's a test shot, but here's what the setup looks like.
5d II + 580ex on camera
bracket + modified pt-04 + pc sync cable
![]() | HTTP response: 403 | MIME changed to 'text/plain' |
Now my issue I BELIEVE is that the cable from the trigger to the camera is not a great connection. I'm ALWAYS pressing in the cable (on both ends) to ensure a good connection. Do you think it would be better to run a pc sync-cold shoe with locking pc sync cables? The 5d II doesn't have a screwlock pc sync does it? Is there a better way to do this?
ALSO ; would anyone recommend the rf602s as a pretty consistent triggering system? Ideally, i'd like to stay cheap for reception stuff just in case someone knocks them down. I know the stratos allow ETTL pass through + remote triggering but they are much more expensive. I do have a set of pixel kings that I use (and like) but they are a bit pricier and would rather not take the chance.
PS as far as range goes, the modified PT04 gets some good range. you can see in this shot that they did in fact trigger the lights from a pretty good distance.
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
and then another 'test' shot from a while ago
IMAGE LINK: http://www.flickr.com/photos/btmlinedan/5129403930/
Modified pt-04 trigger range test
