Thread started 06 Aug 2012 (Monday) 02:36
Battery grip.. why?
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Aug 06, 2012 02:36 |  #1
I have a question about battery grip, why does one choose to use them?
To my understanding the battery grip allows the user to use 4 AA batteries aswell as the original inside the battery grip.
A battery grip costs between $150-$300
Original Canon battery range from $40-$100
So people pay more money in order to be able to use AA batteries that last not even half the time of an original Canon battery. My battery can take around 1500-2000 images before going below 15% capacity, i bought an extra one, this means i can take roughly 4000 pictures with both my batteries for an extra cost of $45.
So a valid argument can't really be the AA batteries, if the battery grip could take two Canon originals inside, then it would be a great argument.
The other option people buy a batterygrip is for stability/heavier camera. But arent tripods/monopods used for this?
And then there is the third options.. the one that some will never admit, that using a battery grip makes the photographer look more "professional".
So, to sum it up.. why?
"High life on low budget"
bent photos (external link)Portfoliobox (external link)
X-Pro1 XF 35 f/1.4
Lowner
"I'm the original idiot"
Aug 06, 2012 02:43 |  #2
In my case its to make the body bigger. I have big hands and it works better. The ability to use AA batteries in an emergency is useful.
Richard
koffikapp
Joined Jun 2012
Aug 06, 2012 02:46 |  #3
Grips can hold two original Canon batteries, at least my 5D II and 7D grips do. There's also battery magazines that can hold up to 6 AA batteries that you can use instead if you so wish, I haven't seen a use for this personally.
I like grips because I can have two batteries inserted, but also because the camera becomes more comfortable to grip when hand-held.
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Aug 06, 2012 02:48 |  #4
koffikapp wrote in post #14820012 (external link)
So there are battery grips that can hold two original batteries? I dident know..
Does this work with all EOS cameras? 600D, 60D, and so on?
X-Pro1 XF 35 f/1.4
Lowner
Aug 06, 2012 02:51 |  #5
bent toe wrote in post #14820013 (external link)
Yes.
Richard
koffikapp
Joined Jun 2012
Aug 06, 2012 02:51 |  #6
Yes, I assume all (original) grips can hold two, as this is one of the main features of a battery grip (hence the name).
Paulos75
Aug 06, 2012 03:22 |  #7
There's a number of advantages to a grip, a number that have been mentioned already.
Capacity for an additional battery and the ability to use a commonly available battery format for that oh sh.. moment.
Makes the camera bigger for those with bigger paws.
Balances out the camera for the bigger lenses. A nicely balanced heavier setup is easier to shoot with than an unbalanced lighter one imo.
It allows you to shoot naturally in portrait orientation as you have the shutter and back button focus buttons + on the grip.
Cheers, Paul.
If it moves, shoot it. If it shoots back, get a bigger lens.
Gear: A slowly but surely growing list of mainly Canon bits and pieces.
Website (external link)Facebook (external link)
Colorblinded
Gallery: 18 photos
Aug 06, 2012 03:45 |  #8
For me it's as much about the vertical controls (when needed) as anything else. On my EOS 3 I never removed the grip and on my 1D Mark II I couldn't. I have a Rebel XTi and no grip for it but I wanted to keep it small. On the 5D3 it's a case by case basis but since I got a good deal on the camera with the grip, it's nice to have when I need it. Shooting in portrait without a grip gets uncomfortable and tiring after a while. The only L bracket I have for tripod use mounts directly to the camera, not sure if I'll get one for it with the grip. If I'm out and shooting in tripod mode I don't usually need the grip (and vice versa).
You also get better balance with bigger lenses when you have a grip.
http://www.colorblinde​dphoto.com (external link)
http://www.thecolorbli​ndphotographer.com (external link)
Joe ­ Ravenstein
Aug 06, 2012 03:50 |  #9
I keep the AA battery pac filled with Eneloops so I know if I ever use that much juice to drain the 2 Canon batteries I will have the 2nd spare battery pac very close to fully charged. I doubt very seriously I will ever get down to the AA batt pac just due to my normal usage when out shooting.
Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
aegid
Joined Apr 2011
Aug 06, 2012 04:52 |  #10
I'm kind of amazed more people don't know there are vertical controls on the grip. A lot of these threads start with the same thing of "it does is let you use two batteries or AA batteries so just pack another battery" like they read part of the product description but not the whole paragraph. As far as price goes, let's just say, "Thanks, China." There's a variety of options to buy.
5d3,17-40,24-105,24 1.4,85 1.4,70-200 2.8 is ii
Lowner
Aug 06, 2012 05:48 |  #11
I have to admit I ignore the controls on my grip. If I'm shooting portrait format my right hand stays exactly where it was, only my left hand slides under the lens. I find it comfortable but I know many don't.
The ability to swop out the Canon batteries and use AA's saved my bacon at the French F1 Grandprix some years ago. It was Sunday, all the shops were shut, my battery charger would not fit the french sockets and both batteries were as dead as the Dodo. But I could buy AA's from a local newsagent. Since then I always carry a loaded "cassette" of AA's in my bag.
Richard
Vixen89
Aug 06, 2012 07:48 |  #12
I like the grips on all of my cameras but especially on the 5D3, the little joystick is awesome to have! It also balances out the camera with the bigger lenses which I like as well and I always forget to charge my batteries too ...then there are days when I travel around for weeks and leave the charger, camera is still good to go on 2 OEM batteries!
I'm actively lazy!! :D | Gear List | photovxn.com (under construction)external link
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Aug 06, 2012 07:49 |  #13
Just for the batteries it would not make sense. For me if you shoot sports where you may need to switch back and forth quickly and comfortably between landscape and portrait orientation, it becomes essential.
Doc Klepper in the USA
I
Jerb
Aug 06, 2012 08:06 |  #14
I think I paid about $40 for mine (for the T2i) and it came with 2 aftermarket batteries. For me that was a bargin and it makes the T2i much more comfortable to handhold.
This is anecdotal but I believe the extra mass and grip area helps me reduce shake as well.
Gripped 7D // Gripped 5Dc // Gripped 5D mkIII ||50mm 1.4 | 85mm 1.8 |135L | 10-22 | 24-70 2.8 | 70-200 2.8 IS | Alien Bees B800 x2 | Alien Bees B400 x2| Waay too many Cybersync Triggers | 6x Yongnuo YN-560 II
ocabj
Aug 06, 2012 08:33 |  #15
Battery grips are a must have for portrait shooting. The controls in portrait orientation is a the huge bonus.
IMAGE: http://www.ocabj.net/wordpress/wp-content/uploads/2012/06/Ocab-20120609-072747-600.jpg
http://www.ocabj.net …-e11-battery-grip-review/ (external link)
Jonathan Ocab - https://www.ocabj.net (external link) - http://jocabphoto.com (external link)
16,679 views & 0 likes for this thread, 44 members have posted to it.
Battery grip.. why?
1456 guests, 128 members online
