Hello. My wife is traveling with the camera and called to say the camera is not working with the 18-55 stock lens, but works OK with the 55-250. Any tips to troubleshoot while she is away?
estebanj Hatchling 5 posts Joined Aug 2012 More info | Aug 07, 2012 19:05 | #1 Hello. My wife is traveling with the camera and called to say the camera is not working with the 18-55 stock lens, but works OK with the 55-250. Any tips to troubleshoot while she is away?
dfdpiper Member 249 posts Gallery: 39 photos Best ofs: 2 Likes: 18 Joined Aug 2010 Location: Geographically I'm in Southern NH, but spiritually & creatively I'm still wandering. More info | Aug 07, 2012 19:09 | #2 Check the contacts on the lens? Check the AF & IS switches? Bob
Saint728 Goldmember 2,892 posts Likes: 1 Joined Jun 2009 Location: Honolulu Hawaii More info | Aug 07, 2012 19:10 | #3 What does she mean not work? Does it not do anything or not focus, or not able to take a picture? Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
imsellingmyfoot Goldmember More info | Aug 07, 2012 19:10 | #4 We need to know what specifically is not working.
First, I would check if the AF switch is in the "ON" position. BLOG
Aug 07, 2012 19:17 | #5 Thank you for the quick replies. I'm on chat with her trying to get more info. Camera turns on OK. It will shoot OK on manual focus. It will not take a picture on auto-focus (with the 18-55) although the flash fires.
imsellingmyfoot Goldmember More info | Aug 07, 2012 19:18 | #6 estebanj wrote in post #14827897 Thank you for the quick replies. I'm on chat with her trying to get more info. Camera turns on OK. It will shoot OK on manual focus. It will not take a picture on auto-focus (with the 18-55) although the flash fires. Is the lens trying to autofocus? Is it moving in and out in a searching manner? I suspect its not getting a focus lock thus not taking a shot. BLOG
Aug 07, 2012 19:22 | #7 She can hear the lens trying to AF. It will flip the flash on as needed. But it won't take a shot.
imsellingmyfoot Goldmember More info | Aug 07, 2012 19:23 | #8 |
Aug 07, 2012 19:26 | #9 Normal light in the room. The 55-200 works OK on AF. Could then 18-55 lens just have gone bad? I'm guessing unlikely but possible?
imsellingmyfoot Goldmember More info | Aug 07, 2012 19:30 | #10 Based on what you've described, I suspect that for some reason the body does not have enough light for autofocus to lock on to something. Bodies are typically set to "focus priority" where they have to have a focus lock before they will allow a picture to be taken. There is a custom function that changes the camera from "focus priority" to "shutter priority." I don't have a T3 so I can't tell you where that is, but hopefully I've given you something else to go on. Someone else can chime in on the specifics, or to disagree with me. I doubt the lens has gone bad. I've dropped my 18-55 and it still focuses fine, although it always has had trouble focusing indoors. BLOG
Aug 07, 2012 19:32 | #11 Thank you. I will have her try again tomorrow outdoors. If problem persists, she can use it in MF until she comes back on Monday and I can further troubleshoot at that time.
Saint728 Goldmember 2,892 posts Likes: 1 Joined Jun 2009 Location: Honolulu Hawaii More info | Aug 07, 2012 19:32 | #12 If the lens can not AF on the subject it will not take a picture. Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
dfdpiper Member 249 posts Gallery: 39 photos Best ofs: 2 Likes: 18 Joined Aug 2010 Location: Geographically I'm in Southern NH, but spiritually & creatively I'm still wandering. More info | I'm leaning toward agreeing with Ben. A question: is the flash firing just the one flahs or is it pulsing? May be that it's firing off an autofocus assist? Bob
JohnfromPA Cream of the Crop 11,262 posts Likes: 1530 Joined May 2003 Location: Southeast Pennsylvania More info | Aug 07, 2012 19:39 | #14 Normal light in the room. The human eye can't really establish "normal" because it has a tremendous range of perceptible light levels. As others have said, low light level is likely the cause. If stuck to the indoors, then as a test point the camera at a light source and see if it now focuses.
kenshap Senior Member 367 posts Joined Dec 2010 Location: What exit? More info | Aug 07, 2012 22:11 | #15 Try the automatic mode and see if it helps. Make sure the lens IS is on and the AF is on. If the flash pops up; strobes and takes a picture. You know all working properly. Just need to figure out what is being done wrong in the mode it's in. Canon T6s (battery grip) | Canon T4i (aftermarket battery grip) | Canon T2i | Canon EF-S 18-55 IS | Canon EF-S 55 - 250 | Canon EF 50mm f/1.4 | Canon EF-S 10-22mm | Canon EF 100mm f2.8L Macro | Canon 40mm
| Latest registered member was a spammer, and banned as such! 2725 guests, 161 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
