Thread started 08 Aug 2012 (Wednesday) 16:15
Lee 'Big stopper' equivalent?
neimad19
Joined Mar 2012
Aug 08, 2012 16:15 |  #1
I've been going through flickr photos that are showing what is capable of the lee 10 stop filter and they look amazing! I really want to have a go at long exposure photography with a filter like this but i don't want to fork out $200+ on something that i'm not certain i will always use.
What are your experience's on low end ND filters? Are they worth it? Can anyone recommend a good ND in the sub $100 range?
I saw this one but I'm skeptical of vivtar/ebay products http://www.ebay.ca …m1e6b34f210#ht_​3110wt_724 (external link)
Damien
LeeRatters
Aug 08, 2012 16:18 |  #2
I've only ever used B+W & find them fine, no issues at all.
>> Flickr << (external link)
>> Instagram<< (external link)
tomme
Aug 08, 2012 18:20 as a reply to  @ LeeRatters's post |  #3
with a cheap filter you will probably have some megenta color cast in it and maybe reduced IQ. ive heard good things about b&w if your looking for screw in filters.
Instagram (external link)
neimad19
Joined Mar 2012
Aug 08, 2012 18:42 |  #4
Yeah after looking around online it looks like B&W is my best bet. Thanks for the input
GuitarDTO
Gallery: 142 photos
Joined Jul 2012
Aug 08, 2012 18:58 |  #5
The BW 10 stop is great and is $110 I believe, a little pricey but not break the bank like the Lee
Gear: 5D3, 135L, Sigma 35, 50 1.8 STM, 16-35 F/4L IS, 85/1.8, Fujifilm X100T
Flickr: DavioTheOne (external link)
skater911
Aug 08, 2012 19:05 as a reply to  @ GuitarDTO's post |  #6
I have the hitech 10 stop pro filter and love it. Had the lee system but didn't use it enough to have 500+ sitting in filters. I think I paid 80 or 90 for it, but make sure you get the pro version. It has the foam gasket to help with light. I got it from 2 filter.
Nikon D850 l Nikon 28 1.4E l Nikon 50 1.8 g l Nikon 24-120 F4 l Tamron 100-400 l
Sirrith
Gallery: 50 photos
Joined Nov 2010
Aug 08, 2012 20:12 |  #7
There is the Hitech pro stop series (6-10 stop), but when I had mine (10 stop), it produced a horrible red cast over some parts of the image which proved impossible to correct, so I returned it and won't buy another one. A friend of mine had the same problem. We both bought ours quite early on, so maybe they have fixed it by now, but I will not chance it again (I had to pay for return international shipping, which is expensive). Now I would only go for the big stopper, stack several weaker NDs, or go for screw in.
-Tom
iTookMyShot
Aug 08, 2012 20:40 |  #8
I like the Schneider vari ND, I got it for a lot less, but it is pricey.. http://www.schneiderop​tics.com …il.aspx?CID=183​8&IID=9137 (external link)
5D mkIV, 2x)7D mkII, 500 f4L IS mkII, 100-400L IS mkII, 70-200 2.8L IS mkII, 24-70 2.8L mkII, 16-35 2.8L mkIII, 100 2.8L IS, 600EX-RT x4
neimad19
Joined Mar 2012
Aug 08, 2012 20:50 |  #9
Digitally_Altered wrote in post #14833074 (external link)
That's only a few hundred shy of what my camera cost!! I'l defiantly go for the screw in type and most likely the B&W as they fall into my budget and have pretty good reviews.
dbricks
Aug 08, 2012 22:19 |  #10
I was in a similar position you are in before travelling to Yellowstone. I wanted a 9 or 10 stop ND filter, but they were so expensive. I did some looking and found some relatively affordable ones on Ebay. They're Hoya brand. Here's a link: http://www.ebay.com …2315eaa770#ht_3​739wt_1186 (external link). I don't know how many people on here would recommend this filter, but it worked well for me and I didn't notice any tint or discoloration in my photos. Plus, it was less than $50. Don't know if that helps or not.
Sony A7III | Tamron 28-75mm f2.8 | Rokinon 14mm f2.8 | Sigma 150-600c + MC-11 adapter
http://davidbricknerph​otography.com (external link)
neimad19
Joined Mar 2012
Aug 08, 2012 22:43 |  #11
dbricks that is what i was looking for! Something cheap that I can use just to see if I like using a 10 stop before forking out $$$
Do you have any pictures with it in use?
Olsenek
Aug 09, 2012 01:54 |  #12
I'm satisfied with my B+W 1000x ND filter.
500D | EF-S 17-55/2.8 IS USM | EF 50/1.8 II | 100/2.8 USM macro | The Magic Drainpipe (EF 80-200/2.8L) | Canon EF 400/5.6L USM | Metz 50 AF-1
Nightdiver13
Unabashed nerd!
Aug 09, 2012 02:24 |  #13
If you're looking to just test the waters without a big investment, you could give welding glass a go. HERE (external link)'s an article about it.
Neil
Jappe
Joined Aug 2012
Aug 09, 2012 02:47 |  #14
Sirrith wrote in post #14832976 (external link)
I bought normal Hitech (not pro stop series) 8 stop ND filter it had also quite(/very) strong purple cast specially when I used it for sunset photos. Partly this comes from IR that ND filter doesn't filter and camera sensors will record IR also. Camera sensor's IR filter will not block all IR away.
B+W 486 filter would kill IR, but I haven't bought it yet. Anyway I was not happy with Hitech color cast problem.
B+W 10 stop ND will add some warm cast to image. Here is info from B+W webpage:
With a light intensity reduction of ten f-stops, this B+W Neutral Density Filter has a slightly stronger warm tone than the ND 106. Its principal field of application is the observation and documentation of industrial processes with extreme brightness, such as steel furnaces, incinerators, glowing filaments in halogen- and other bulbs. The filter factor is 1000x.
That is not normally a problem but it's good to know that it would not cause unexpected effects when filter is used.
KirkS518
Joined Apr 2012
Aug 09, 2012 04:31 as a reply to  @ Jappe's post |  #15
I'm going to go against the grain here with my recommendation(s), which are based on budget priority.
I also wanted to try out the NDxxx for the long exposures, but no way in hell was I going to shell out $100 or more to try it out. I found a used Hoya ND8 on ebay for $12, and I like it, but want darker still.
Last week I stopped my a welding shop, picked up a 10 Shade welding lens ($3.60), and made a filter. Came out ok, and it does give you crazy long exposures. I only took a couple of shots with it so far, and mostly just tests. With the welding glass, you do have to correct the WB, as they give a really dark green tint to everything. (See pics)
My next pruchase will be one of those really cheap variable ND flters you see on ebay for about $10. Yeah, yeah, they're cheap, and most of these guys will tell you they're garbage, and that's what I thought. But another forum member bought one, and posted a thread about them with pics, and while they aren't perfect, they are perfectly acceptable for a hobbyist/enthusiast. I can't find the thread, but it's less then a month old.
So, depending on where you are budget-wise, and whether you consider yourself a pro, amateur, enthusiast, hobbyist, or a guy with a cam, you have choices that run the full spectrum (so to speak). Once my cheap-o variND arrives, I'll take some shots and post them.
#1 - Untouched (resized only)
IMAGE: http://i486.photobucket.com/albums/rr224/Beefer518/Camera%20stuff/untouched.jpg
#2 - Quick correcting (about 2 minutes)
IMAGE: http://i486.photobucket.com/albums/rr224/Beefer518/Camera%20stuff/retouched.jpg
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
5,902 views & 0 likes for this thread, 17 members have posted to it.
2693 guests, 146 members online
