Thread started 08 Aug 2012 (Wednesday) 16:26
Bright Sunlight Pictures
TRACER
Joined Nov 2010
Aug 08, 2012 16:26 |  #1
Quick question: Why does it seem like whenever I take pictures in bright sunlight the photos don't look "smooth" and really sharp. It is not camera shake or focus issues, it's different than that. This seems to happen frequently in sunshine photos. Can the sun cause your pictures to be too sharp (if that makes sense). Do I need to compensate for bright sunshine and underexpose a bit to get my photos sharper?
Any advice is appreciated.
Thanks,
Randall
Randall
7D,Tamron 70-300 F/4-5.6 Di VC USD; Canon 15-85
Laramie
Still livin' the cowboylife
Aug 08, 2012 16:35 |  #2
Do you have any sample pics that demonstrate the issue you're having?
5DIII | 40D | 17-40 f4L | Tamron 28-75 2.8 | 50 1.4 | 70-200 2.8L | Oly Zuiko 50 macro | Tamron 1.4x
MikeWa
Gallery: 89 photos
Joined Apr 2012
Aug 08, 2012 16:48 as a reply to  @ Laramie's post |  #3
If you are trying to take long range pictures air shimmer and evaporated moisture can have an affect. Even though you may not see them with your eyes either or both can screw up your photo. Sample pictures would help.
Mike
Mike...G9; 7D; 7D Mark II; EF-S 10-22mm; EF-S 18-135mm IS STM; EF 28-300mm F3.5-5.6L; EF 70-300mm IS USM; EF 70-200mm F2.8L IS-II; EF 100-400mm f4.5-5.6L IS; EXT 1.4-II & 2.0-III; The more I learn the less I know.
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Aug 08, 2012 16:51 |  #4
Bright sunlight can also exceed the dynamic range of your camera. The difference between bright and dark are too much so you either lose highlights or shadows, and thus you loose the sense of smoothness. Most good landscape photography is done early and late. Portrait photography too for that matter.
ickmcdon
Joined Apr 2012
Aug 08, 2012 23:30 |  #5
Pics in bright sunlight may also force very small apertures, which creates diffraction and resulting softness.
TRACER
Joined Nov 2010
Aug 09, 2012 07:59 as a reply to  @ ickmcdon's post |  #6
Thanks for the replies.
Randall
Randall
apersson850
Obviously it's a good thing
Gallery: 35 photos
Aug 09, 2012 08:09 as a reply to  @ TRACER's post |  #7
True too, but usually pictures taken in bright light (which often is sunlight) are of subjects showing a very high contrast, and a large range between brightest and darkest point.
A soft light, filtered through clouds or something, will illuminate much more evenly, and thus make the images look soft and flat.
Anders
yalemba
Joined Sep 2003
Aug 09, 2012 09:50 |  #8
TRACER wrote in post #14832168 (external link)
Thanks,
Randall
If you meter the subject correctly, and avoid the glare, there is no reason why the picture will be less sharp. I usually use an off-camera flash for my sun light pictures...
Cameras: 1DX, 1Ds Mark III
Lenses: 24 TSE II, 50L, 85L II, 24-70L II, 70-200L II
Flash: 600 EX with STE3, Einstein
wayne.robbins
Joined Nov 2010
Aug 09, 2012 20:09 |  #9
Try a CPL or maybe a ND filter ... If possible- move the subject out of sun if possible. Shoot earlier in the day or shoot later in the evening. Shoot in Manual or AV modes- avoid the dreaded green box and fully automatic modes.
EOS 5D III, EOS 7D,EOS Rebel T4i, Canon 70-200 f/2.8 IS II, Canon 24-105L, Canon 18-135 IS STM, 1.4x TC III, 2.0x TC III, Σ 50mm f/1.4, Σ 17-50 OS, Σ 70-200 OS, Σ 50-500 OS, Σ 1.4x TC, Σ 2.0x TC, 580EXII(3), Canon SX-40, Canon S100
Fond memories: Rebel T1i, Canon 18-55 IS, Canon 55-250 IS, 18-135 IS (Given to a good home)...
kfreels
Aug 09, 2012 20:56 as a reply to  @ wayne.robbins's post |  #10
Lots of good comments. What are you usually shooting where you notice this? In such situations shoot with ISO 100 and use higher shutter speeds if possible to keep from using those really small apertures that cause diffraction. As stated above, see if you can move subjects to shade or use reflectors to fill so you can reduce contrast and drop exposure without losing the shadows. If you are doing landscapes, try doing multiple exposures bracketed so you can create an HDR image and increase dynamic range. ND filters can help but have to be used carefully to prevent flare and you can't use cheap ones because you'll get distortion and color casts. Bright sunlight is generally a royal pain in the rear which is why most of us try to avoid it if at all possible.
I am serious....and don't call me Shirley.
Canon 7D and a bunch of other stuff
kasey
Aug 09, 2012 22:56 |  #11
Could it be chromatic aberration?
Do you notice cyan or magenta color fringes in some high contrast areas? A good description of CA is here:
http://en.wikipedia.or​g/wiki/Chromatic_aberr​ation (external link)
Try using a smaller aperture.
TRACER
Joined Nov 2010
Aug 10, 2012 13:36 as a reply to  @ kasey's post |  #12
After reading all the replies, the sharp contrast seems to make the most sense. It's as if the lines (i.e. a person's face as it seperates into the background) is not sharply defined. You have to look close (not necessarily pixel peep), but there just isn't the clearly defined seperation at the edge of objects. Not softness or out of focus, just ......maybe "harsh" is a better word. I notice it more with people's faces than anything else.
Make sense?
Randall
Randall
rrblint
Gallery: 84 photos
Joined May 2012
Aug 10, 2012 13:41 |  #13
TRACER wrote in post #14840951 (external link)
Make sense?
Randall
Try fill flash on faces in bright sunlight...I think you will see some improvement.:)
Mark
kfreels
Aug 10, 2012 13:56 |  #14
Make sense?
Randall
Yeah. Sounds like you have a bad case of contrast. As others have mentioned, samples would tell us a lot more. Without samples we're stuck with guessing.
2,790 views & 0 likes for this thread, 11 members have posted to it and it is followed by 2 members.
887 guests, 130 members online
