Thread started 08 Aug 2012 (Wednesday) 16:45
Leaving my T3i ON/OFF switch at ON?
Scrumhalf
Gallery: 158 photos
Joined Jul 2012
Aug 08, 2012 16:45 |  #1
Newbie question - I have been leaving the ON/OFF switch at ON all the time, since the camera turns itself off after a few minutes and I can quickly get it back awake by pressing the exposure button. But then I got thinking that this way, it does not do its sensor clean procedure at all... is that a bad thing? Should I be turning the camera hard OFF at the end of the day at least?
Thanks!
Sam
5D4 | R7 | 7D2 | Reasonably good glass
If I don't get the shots I want with the gear I have, the only optics I need to examine is the mirror on the bathroom wall. The root cause will be there.
c2thew
Aug 08, 2012 16:48 |  #2
it shouldn't matter really. If your sensor is always dirty, than yes a hard off switch would be wise. Leaving the camera in on affects battery life since the camera determines when it turns off after 1 to 2 minutes vs when you hit the off switch.
aside from that, the battery is always connected to the camera so it will drain slowly over time.
Flickr (external link) |Gear|The-Digital-Picture (external link)|The $6 mic | MAGIC LANTERN (external link) | Welding Filter
Go Support Magic Lantern 2.3!!
Albert ­ Nam
Joined May 2011
Aug 08, 2012 16:51 |  #3
At the end of a shoot or at the end of the day, maybe. Just so that things don't get accidentally activated while your camera is in your bag, etc. I think you can manually activate the sensor cleaning (not to be confused with manually cleaning the sensor) through the menus every now and then. It's more extensive than the automatic startup/shutoff cleaning.
Gear
683 views & 0 likes for this thread, 3 members have posted to it.
2734 guests, 161 members online
