Thread started 08 Aug 2012 (Wednesday) 21:55
Keep the lens caps on while in the field?
tvphotog
Aug 08, 2012 21:55 |  #1
Just a matter of technique and convenience. When you carry a bag with several lenses that you think you will have to switch to quickly, do you keep the front and rear lens caps on each of them, or leave both off so you don't have to bother unscrewing and rescrewing during a lens change?
Do you worry about getting them dirty if you leave them bare front and back?
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
rick_reno
Aug 08, 2012 22:11 |  #2
i leave them capped, front and rear.
crn3371
Aug 08, 2012 23:06 |  #3
If I'm regularly changing lenses I'll leave the front cap off but put the rear cap on. Aside from keeping the rear element clean I figure I'm also keeping the mount from possibly getting dinged up.
darosk
Aug 08, 2012 23:11 |  #4
^Ditto. Back cap to keep rear element clean and minimize risk of anything transferring from the rear element to the sensor. Front element usually stays off, but hoods are on if I got space for em.
Tumblr (external link) | Facebook (external link) | Youtube (external link)
Gear
mike_d
Aug 09, 2012 01:17 |  #5
darosk wrote in post #14833873 (external link)
Yep. I always use hoods and that means that the front element isn't even touching the bottom of the bag.
armis
Joined Jan 2012
Aug 09, 2012 03:29 |  #6
Capped, front and rear - though I could see using a hood instead of the front cap if I had the room to accomodate them, which I don't.
Fuji X-T4, 18-55 and 55-200 zooms, Samyang 12
www.wtbphoto.com (external link)
sandpiper
Aug 09, 2012 03:40 as a reply to  @ armis's post |  #7
If I'm actually carrying the bag around, then the caps will be on both ends. If I am pretty much shooting from one place, so the bag is just lying on the ground, then I may drop uncapped lenses in there and carry on shooting. I generally minimise the need for rapid swapping by carrying two (or three) bodies with different lenses on. So, at an airshow for example, I might have the 10-22 on my crop and the 24-105L on my 5D in the morning for the flightline walk / static park, then switch to a combo with the 300 2.8L and 100-400L fitted for the afternoon air display.
I may decide that I want a shorter fast prime on at some time during the morning, for some shallow DOF shots, in which case I will switch one of the bodies over for a while. I will leave the caps off, if I plan to take the shots and then swap the lens back, put the caps on if I am going to leave it on for a while and wander around.
I don't baby my gear though, and if it comes down to getting the shots or putting the caps on, then I get the shots and worry about the gear later.
Channel ­ One
Joined Nov 2010
Aug 09, 2012 06:18 |  #8
tvphotog wrote in post #14833421 (external link)
Rear only, never bothered with using front caps.
Wayne
Do what you love and you will love what you do, that applies to both work and life.
RangersForever
Joined Jun 2010
Aug 09, 2012 07:45 |  #9
Usually rear only with the front protected by hood and filter.
Scotland Wedding Photographer (external link)
BigSky
Aug 09, 2012 11:17 as a reply to  @ RangersForever's post |  #10
Unless the bag is sitting there without the intent of being moved, can I assume those of you who state that you keep the rear cap on but not the front are all talking about a situation where there is a hood and/or filter in place?
DavidR
Aug 09, 2012 15:55 |  #11
BigSky wrote in post #14835750 (external link)
For me yes, hood is always on and in shooting position.
Most of my lenses are in the bag like this (ready to shoot). Other than a little more dust on the front element what harm could happen?
Sony a9II
jones17
Aug 09, 2012 16:11 as a reply to  @ DavidR's post |  #12
Both front and back on, except if hood on then no front cap.
Canon 7D | Tokina 11-16 | Canon 24-70 L | 70-200mm f4 IS L
tzalman
Fatal attraction.
Aug 09, 2012 16:42 |  #13
Kinda' depends. Usually I will be going between the 24-70 and the 70-200. The 70-200 hood is really deep so I'm not worried about it picking up lint, dust, dirt from the bottom of the bag, but I have to be careful about it being so long that the lens can fall out of the bag. Besides getting my hand inside there to remove the stupid Canon cap is a PITA. But the 24-70's hood is very shallow, so I'm more likely to put it on when putting the lens in the bag.
Elie / אלי
kfreels
Aug 09, 2012 18:35 |  #14
crn3371 wrote in post #14833859 (external link)
Same here. I keep lens hoods on when swapping lenses at a shoot and my bags sre clean and free of other parts or debris in the lens compartments. so the lens element never actually touching anything when I put it in the bag lens-down with the rear cap on.
I am serious....and don't call me Shirley.
Canon 7D and a bunch of other stuff
elogical
Aug 09, 2012 18:42 |  #15
the front element at least can be cleaned easily as long as you don't scratch it. The rear on most lenses are a little more open and present too much opportunity for dust to get into areas you can't easily clean.
Although, in casual observation of some pros shooting events, I have seen a number of photogs who would set down the lenses with no caps front or rear. I'm assuming most of these people are CPS members who just send the lenses in for regular cleaning? I'm too paranoid to leave a lens sitting out with no rear caps.
Gear
4,169 views & 0 likes for this thread, 19 members have posted to it.
2453 guests, 105 members online
