Nightstalker wrote in post #14839023
I'm with Moppie - I never ejected media from Windows 7 and I have never suffered any data loss or corruption.
I understand why it can be done but in my experience just pulling the card / pen drive out does not do any harm whatsoever.
Windows defaults to support quick-removal for the memory card readers, so pending data gets written down immediately instead of staying buffered for a save at a later time. It makes writes to the cards a bit slower, but the advantage is that it's enough to wait until the blinking light ends - unless you use special programs that themselves keep data unsaved in memory. Problem is that that type of programs will most probably not hook the event chain in Windows, so "safe removal" would not manage to convince them to quickly save the data before the removal.
So in the end - just check the blinks.
By the way - there is a registry setting that controls if SATA drives should be removable or not. There needs to be a DisableRemovable = 1 in the registry. Alas, I don't know what the registry path to the SATA driver would be for your specific computer. But if you google a bit, you can probably find a utility program that will give you a checkbox or something to specify if the SATA drives should show up or not among safely removable hardware.
