Thread started 09 Aug 2012 (Thursday) 16:59
canon 60d
silvi
Joined Aug 2012
Aug 09, 2012 16:59 |  #1
Hi guys, I have a little issue with my canon 60D. I'm shooting some interior pics for a kitchen catalogue and they all came out not perfectly sharp. I sent one sample pic to the Canon technical support but they keep saying that the pic is perfectly sharp. Is there anybody out there who wouldn't mind giving a look at my pic and tell me his-her opinion?
I checked every possible setting on the camera and everything seems fine. On my part I really can't find anything that I could have done wrong. I also used 2 different lenses with the same soft focus result which makes me think it's not the lenses either.
RHChan84
Joined Apr 2011
Aug 09, 2012 17:07 |  #2
Do you have a sample pic? With EXIF?
What lenses?
If you do not have a sample photo with EXIF, do you remember settings? f-stop, ISO, shutter speed?
Canon (60D Gripped | 18-135mm f3.5-5.6 IS | 40mm f2.8 | 50mm f1.8 | 70-200 F4L IS| 430 EXII)
Tamron (17-50 f2.8 VC)
Feedback
Facebook (external link)
dpds68
Aug 09, 2012 17:34 |  #3
Can you post a sample ?
David
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
wayne.robbins
Joined Nov 2010
Aug 09, 2012 19:44 |  #4
Interior ? Are you using a flash or strobe ? How well lit is the subject ? Exif settings from the pic, and posting the pic itself- will help immensely. Proper lighting is critical indoors - especially for sharpness / softness issues.
Which lenses ?
EOS 5D III, EOS 7D,EOS Rebel T4i, Canon 70-200 f/2.8 IS II, Canon 24-105L, Canon 18-135 IS STM, 1.4x TC III, 2.0x TC III, Σ 50mm f/1.4, Σ 17-50 OS, Σ 70-200 OS, Σ 50-500 OS, Σ 1.4x TC, Σ 2.0x TC, 580EXII(3), Canon SX-40, Canon S100
Fond memories: Rebel T1i, Canon 18-55 IS, Canon 55-250 IS, 18-135 IS (Given to a good home)...
watt100
Aug 10, 2012 05:21 |  #5
yes, you need to post pics !
bratkinson
Joined Dec 2011
Aug 10, 2012 06:27 |  #6
This exact thread from the same poster is on another web site as well.
Without pictures and EXIF information, nothing can be determined.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." General George S Patton, Jr 1885-1945
John ­ from ­ PA
Joined May 2003
Aug 10, 2012 07:32 |  #7
OP, if nothing else, post here the picture you sent to Canon.
tccin3D
Aug 10, 2012 08:31 as a reply to  @ John from PA's post |  #8
Bump up sharpness and contrast in your camera, it may be set to zero. If Canon says its ok than it is just the setting in your camera that needs correction.
silvi
Joined Aug 2012
Aug 10, 2012 09:32 |  #9
Ok I attached here the jpeg pic I sent to Canon. You should be able to see the info but just in case...
manual
iso 800
f13 0.4
focal length 18 mm
lens ef-s 18-135
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/08/2/LQ_609702.jpg
Image hosted by forum (609702) © silvi [SHARE LINK]
silvi
Joined Aug 2012
Aug 10, 2012 09:40 as a reply to  @ wayne.robbins's post |  #10
Wayne the lighting in this showroom is pretty terrible.No natural light just the beams you see in the pics and a few more on the ceiling. Originally they were supposed to pay for the strobe rental but they changed their mind. As for the flash I did use mine in a couple of pics but I didn't like the effect. Do you think I should give one more try to the flash?
silvi
Joined Aug 2012
Aug 10, 2012 09:42 as a reply to  @ tccin3D's post |  #11
tccin since I'm shooting both jpeg and raw and only using the raw files I don't need to set sharpness and contrast on my camera.
alwaysDSLR
Joined Jul 2011
Aug 10, 2012 09:43 |  #12
I supposed the white balance can be adjusted for an overall improvement of the colour?
Canon | 5D3 | 50 f1.2L USM | 24-105 f4L IS USM | 70-200 f4L USM | 100 f2.8L Macro IS USM
silvi
Joined Aug 2012
Aug 10, 2012 09:59 as a reply to  @ alwaysDSLR's post |  #13
alwaysDSLR thanks for your reply. I'm not concerned with white balance since I'm using the raw files. The issue is the sharpness.
ScullenCrossBones
Aug 10, 2012 10:16 |  #14
Did you add sharpness in post? Also, why are you shooting raw and jpeg if you're only going to use raw?
Sharpness in the cam will affect the jpeg. F13 is not ideal for sharpness. Do you need to shoot at that setting for DOF? F8 would be better if you can get away with it wrt DOF.
:p Gear
Mama done took my Kodachrome away...
silvi
Joined Aug 2012
Aug 10, 2012 10:36 |  #15
no the jpeg I posted is exactly how it was shot but the problem is that the raw file looks more or less the same and even after fixing the sharpness in raw I still see that annoying soft focus. I'm using the raw files but I like to have jpegs in case my clients want to see the pics right away. I went for f13 because I was trying to have a good dof without long exposure time. Do you think F8 might work better? I'll give it a try. Also, I used to have a canon 7d which got stolen so maybe I was just used to that camera...much sharper pics.Thanks for your reply.
3,543 views & 0 likes for this thread, 12 members have posted to it.
canon 60d
2862 guests, 158 members online
