Thread started 10 Aug 2012 (Friday) 20:19
inconsistent focus with 70-200 2.8L mkI
Ltdave
it looks like im post #19,016
Gallery: 24 photos
Joined Apr 2012
Aug 10, 2012 20:19 |  #1
ive been playing around with my 70-200 and it seems as if i have inconsistent focus sharpness...
sometimes it looks pretty good and other times there are definitely some fuzzy looks...
is this something that could be remedied with a trip to Canon? id like to get a good focus target and shoot some pics off a tripod to confirm my suspicions first of course but definitely need some peace of mind...
-im just trying. sometimes i succeed
Nightdiver13
Unabashed nerd!
Aug 10, 2012 21:12 |  #2
Ltdave wrote in post #14842192 (external link)
I'd definitely run it through a quick test on a tripod before going into too much worry. I notice that sometimes I'll forget about the focal length I'm shooting at, and then when I review my pics later I'm wondering why my 200mm at 1/80th of a sec isn't looking as sharp as I like. Not to say that's the case here, but good to do a controlled test to see if you can reproduce the problem.
Neil
TSchrief
Joined Aug 2012
Aug 10, 2012 21:25 |  #3
I just bought a Sigma 70-200 OS HSM. I can get some fuzzy shots by shooting at 200mm, f/2.8 and focusing at 10 feet. DOF is like 1/4" under those circumstances. What are the shot parameters? Could you be asking too much of the lens? As NightDiver13 said, some controlled tests are in order.
Ltdave
Gallery: 24 photos
Joined Apr 2012
Aug 10, 2012 22:05 as a reply to  @ TSchrief's post |  #4
yes, i very well could be...
thanks for the input everyone...
tompfeiffer
Aug 11, 2012 00:08 |  #5
DOF at 10' at 2.8 is actually about 2 feet, not .25"
Test at f/4, virtually every shot should be spot on.
40D, 20D, T3i, 10-22, 17-40L, 24-105L, 70-200 2.8L IS, 70-300L, 50 1.4, 85L, 180 Macro, 18-55IS, 18-135IS, 55-250IS and a handful of others.
TSchrief
Joined Aug 2012
Aug 11, 2012 01:29 |  #6
tompfeiffer wrote in post #14842999 (external link)
Please back up that statement. According to this web-site: http://www.dofmaster.c​om/dofjs.html (external link) DOF with a crop sensor is as follows:
f/2.8, 10', 70mm - DOF = 8 inches.
f/2.8, 10', 200mm - DOF = less than 1 inch. (Edit on this line, 200 not 2000 as originally mis-typed)
As supporting evidence I submit the attached photograph. Shot with 60D and Sigma f/2.8 70-200 OS HSM. ISO=100, f/2.8, 200mm, direct flash from a 550EX, focus is on the building above the the second "I". The wine bottle is a measured 10 feet from the sensor plane. The biscuits are 4" behind the front of the wine bottle, clearly OOF. The pop bottle is 3" in front of the wine bottle, again clearly OOF. The wooden chair is 12" behind the biscuits. There is very clearly nothing approaching 2' DOF. The "G" on the wine label is out of focus, as is the small printing on the left edge of the label. As you can see, they are less than an inch apart, front to back, so DOF is less than 1". This does not verify the web-sites calculations, but it most certainly does corroborate them.
If a f/2.8 lens really delivered 2' DOF at a focus distance of 10', nobody would ever buy one. Blurred-out backgrounds would be impossible. Also, if DOF were 2 feet at a focus distance of 10 feet and the lens could not produce a good picture, I would assume the AF is broken.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/08/2/LQ_609806.jpg
Image hosted by forum (609806) © TSchrief [SHARE LINK]
wayne.robbins
Joined Nov 2010
Aug 11, 2012 12:45 |  #7
@TSchrief May want to edit your post for 200 ..
And I would suppose the aperture blades were stuck/broken and thus stopped down with a 2 foot DOF @ 10 feet. But I guess - something broken is still something broken.
EOS 5D III, EOS 7D,EOS Rebel T4i, Canon 70-200 f/2.8 IS II, Canon 24-105L, Canon 18-135 IS STM, 1.4x TC III, 2.0x TC III, Σ 50mm f/1.4, Σ 17-50 OS, Σ 70-200 OS, Σ 50-500 OS, Σ 1.4x TC, Σ 2.0x TC, 580EXII(3), Canon SX-40, Canon S100
Fond memories: Rebel T1i, Canon 18-55 IS, Canon 55-250 IS, 18-135 IS (Given to a good home)...
TSchrief
Joined Aug 2012
Aug 11, 2012 13:20 |  #8
wayne.robbins wrote in post #14844613 (external link)
My wife is constantly telling me not to proof-read my own writing. Thanks for catching that.
Ltdave
Gallery: 24 photos
Joined Apr 2012
Aug 11, 2012 13:47 as a reply to  @ TSchrief's post |  #9
3 photos...
ISO 100
distance of about 25'
Av exposure mode
on a tripod (not a GOOD tripod but a pretty close to USEABLE tripod lol)...
f32 - 1/6s
f11 - 1/50s
f2.8 - 1/640s
i think the first at f32 is a bit blurry due to the shutter speed more than a focus issue. i wanted to keep the ISO down for the best noise but i guess with the crappy weather i should have sacrificed the grain and run it higher...
snyderman
Aug 11, 2012 15:45 |  #10
Couple of questions:
1. What body are you using?
2. Why would you choose f/32 for ANY shot?
3. Did you use the timer shutter release AND turn OFF the IS on the lens during tripod use?
Comments: The 70-200 f/2.8L should be really sharp at f/2.8 - f/11; 1/6" and 1/50 are pretty slow shutter speeds. The rule of thumb for shutter speed is like twice the focal length used. At 200mm you should be around 1/400.
dave
Canon 5D2 > 35L-85L-135L
Nightdiver13
Unabashed nerd!
Aug 11, 2012 17:49 |  #11
The f11 and f8 shots look fine. The f32 shot isn't surprising, even if you used a faster shutter. You say sharpness is inconsistent. Is that something you notice under certain circumstances? When you review your images, do you notice a trend of which ones aren't sharp? I ask because three shots taken at very different settings isn't enough to gauge if you're having consistency issues.
Neil
AbPho
Aug 11, 2012 19:29 |  #12
Ltdave wrote in post #14844817 (external link)
3 photos...
At f/32 you are pushing the resolving power of a lens. Diffraction will make the image look soft (or out of focus). Did you turn off IS when using the tripod? That can also be a contributor.
I'm in Canada. Isn't that weird!
rx7speed
Aug 12, 2012 00:48 |  #13
I will say I've seen the same thing with my 70-200 MKII. I've put it on a tripod, remote release, subject is a non moving object.
focus, take shot, manually unfocus it them have it refocus. If I do it over and over some shots are spot on some are not. sent to canon and they said they fixed it. Still same problem exist. I could even sit there and just tap the autofocus button without touching anything else while it was on a tripod and watch the focus point change around.
might be just the way it is. Not sure though.
digital: 7d 70-200L 2.8 IS MKII, 17-55 2.8 IS
tompfeiffer
Aug 12, 2012 00:59 |  #14
[QUOTE=TSchrief;148431​98]Please back up that statement. According to this web-site: http://www.dofmaster.c​om/dofjs.html (external link) DOF with a crop sensor is as follows:
http://2.bp.blogspot.c​om …KCuWf04MxG0/s16​00/DOF.jpg (external link)
But that's actually for a 50mm lens, at 70mm f/2.8 it's only about a foot, but still not .25". See here:
http://www.johnhendry.​com/gadget/dof.php (external link)
Sorry for the confusion.
snake0ape
Aug 12, 2012 02:27 |  #15
On tripod and with a hefty lens at 200mm, the vibration from the shutter is enough to cause blurry pictures like this. Did you use lens collar, mirror up, 2 sec shutter, IS off and on solid ground?
5Diii | 50D | 8-15L 4| 16-35L 2.8 II| 24-70L 2.8 II | 70-200L 2.8 IS II |Tamy 150-600 | Σ35Art 1.4 | 40 2.8 | Σ50Art 1.4 | 85L 1.2 II | 100 2.8 Macro | Helios 44-3 58mm f2.0 |Helios 40-1 85mm f1.5 | 1.4x & 2x teleconverters
4,976 views & 0 likes for this thread, 9 members have posted to it.
2771 guests, 142 members online
