I upgraded both of my camera's to the new 2.0 firmware. However, when setting the audio to manual with a rode videomic pro plugged in, the levels never drop to zero and maintain a noise. I tried 2 rodemic pro's on both of my 7D's and the same issue occurred, once I unplug them, the levels drop to zero and work perfectly with just the onboard mic. I also tried a zoom h4n and though the result was a lower hum, the levels never dropped to zero in a quiet room... just maintained a low hum. Obviously I adjusted the audio manually but the only way for the room to register with no noise was to unplug the mic. I tested the same mic's on a 5d mark ii and the levels were perfect when adjusting manually and there was no constant hum/noise.
Anyone else test this?
