Thread started 11 Aug 2012 (Saturday) 19:07
choose card manually & error 70
laraH
Joined Aug 2011
Aug 11, 2012 19:07 |  #1
camera — 5D mark III — this is probably a silly question, but is there a way to manually switch the card slot you want to use? sometimes, depending on the order in which i load the cards, the card in the 2nd slot will write info first.
i only want to use SD slot if the compact flash card is full. but i can't seem to find a "button" that allows me to choose which disk i want to use.
also, if i work on my digital files in photo mechanic, edit or trash some images, and then put the card back in the camera i get the error 70 message - which requires me to take the battery and out and reinsert. last time i this problem the battery trick didn't work. it was a good thing i was home and could remove all the images off the card manually and then empty the trash on my laptop. then i could format my card.
i am using a new lexar udma 32 mg card.
i haven't found a good explanation for this phenomena or any fix other than the battery one.
thoughts?
thanks, lara
"sorry i think i put this in the wrong forum."
Dennisuye
Aug 11, 2012 21:10 |  #2
Hi Lara
Try this for recovering from a error 70
http://www.reikan.co.u​k/photography/blog/?p=​1550 (external link)
laraH
Joined Aug 2011
Aug 12, 2012 18:20 |  #3
Dennisuye wrote in post #14846223 (external link)
Hi Lara
i really don't want to have to "recover" from the error, i just want it to not to happen at all. so this is something i have to send the 5D in for? i just bought it about 6 weeks ago, so it is still on warranty. this is a camera problem?
sigh...
thanks for the info!
1,159 views & 0 likes for this thread, 2 members have posted to it.
2877 guests, 169 members online
