Thread started 12 Aug 2012 (Sunday) 10:27
Think my flash is broke
godzilla ­ IN ­ macro
Joined Jun 2012
Aug 12, 2012 10:27 |  #1
Got a jessops 360afd couple weeks back and it was fine the day I got it. Put it back in box with batteries still in took it out to use today replaced batteries with new ones as presumed they would have drained , now flash won't do anything not even turn on . Anyone experience this before
canon 550d/50mm F1.8/18-55II is kit lens/55-250II zoom/100mm f2.8 macro usm/jessops 360afd/yn560II/manfrot​to mono and tri pods/magic lantern/
dedsen
Aug 12, 2012 10:37 |  #2
Make sure that the new batteries are actually new and good. Check to see if you accidentally installed one or more batteries in the wrong direction.
I would suggest that you not get in the habit of storing your flash with batteries installed. Especially if you use alkalines. It is a bad habit that eventually leads to leaky batteries and corroded terminals.
Joined Jun 2012
Aug 12, 2012 10:45 |  #3
dedsen wrote in post #14848138 (external link)
Brand new in opened . Just waiting on a rechargeable set to finish so I can try those .
Joined Jun 2012
Aug 12, 2012 11:13 as a reply to  @ godzilla IN macro's post |  #4
Working now maybe capacitors needed to decharge or something ,
dedsen
Aug 12, 2012 11:30 |  #5
Happy to hear you got it working. There should not be any kind of discharge period. Just install good batteries in the correct configuration and it should work.
1,093 views & 0 likes for this thread, 2 members have posted to it.
1428 guests, 169 members online
