Thread started 13 Aug 2012 (Monday) 03:23
Increase Continuous Shoot
andyoftheg
Joined Aug 2012
Aug 13, 2012 03:23 |  #1
Morning All,
I'm new to the forum, so please accept my apologies if this question has been answered in the past ( I did look first).
I am using an EOS 500D, and find the 10 exposure continuous shoot a little limited.
Is it possible to increase this limit through a firm wear hack or PC link up?
I had heard of software that allows you to connect the camera to a pc via USB, and then control the exposure and setting from their, and was hoping this would be the key.......but i still have not found what I'm looking for.
Any help would be very much appreciated.
Cheers,
Andy
p.s. my reason for wanting to do this is so that I can try multi shots of the night sky to stack in PS
seall
Gallery: 14 photos
Joined Mar 2012
Aug 13, 2012 04:08 |  #2
Hi Andy, greetings!
Have you checked out an intervalometer?
You may also find "Magic Lantern (external link)" to be very helpfull, saves buying an intervalometer...
Slàinte
PaulB
Joined Apr 2003
Aug 13, 2012 04:53 |  #3
andyoftheg wrote in post #14851205 (external link)
Morning All,
Do you mean the buffer size?
If so then as the buffer fills it will be writing to the memory card and as soon as there is space another image can be taken and written to the buffer - and so on.
There is absolutely nothing you can do to increase the size of the memory in the buffer.
What you can do is:
Use a smaller image resolution - increasing the number of images that the buffer can hold. Are you using RAW? If so use JPEGs.
Use a faster memory card - to write from and clear the buffer faster.
The speed of your memory card is most probably the bottleneck.
I don't know what speed card you are using but at least a Class 10 would help.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Aug 13, 2012 04:59 as a reply to  @ PaulB's post |  #4
I think he's talking about the continuous shooting after the self timer has expired. Some of the simpler cameras have this gimmick. Perhaps only those that don't have the N3 connector, so they can't easily connect to Canon's TC-80N3.
Continuous shooting with self timer works like waiting the ten seconds, then taking the set number of frames in continuous mode. But then probably not more than ten in a row.
EOS Utility (free with camera) contains functionality to program timer controlled shots. Check to see if it has what's needed for you.
Anders
andyoftheg
Joined Aug 2012
Aug 13, 2012 05:25 |  #5
apersson850 wrote in post #14851329 (external link)
That is exactly what I'm talking about.
I'll have a look at the Utility disk and see what I can find.
Many thanks,
Andy
waterrockets
Joined Jun 2010
Aug 13, 2012 09:27 as a reply to  @ andyoftheg's post |  #6
seall wrote in post #14851255 (external link)
Hi Andy, greetings!
Slàinte
shariffmorgan wrote in post #14851461 (external link)
I you want technical detailed information about using magic lantern you can visit this link: http://magiclantern.wi​kia.com/wiki/Unified/U​serGuide (external link) , It has really helped me a lot as beginner, hope it works for you also.
Magic Lantern is your answer for sure. Intervalometer will fix you right up.
Also, if you use it and like it, throw a donation at the developers so they can keep up with new cameras and new features.
1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
1,584 views & 0 likes for this thread, 5 members have posted to it.
2877 guests, 169 members online
