Hi guys, been trying to figure out something.
So, I'm checking out Benro new MeFoto travel tripod and the thing is small, compact seems sturdy. I read some good reviews about it, decided to give it a try.
Went to a store selling those and since they couldn't find an available Canon to mount on it, we settled for Nikon D3x and 70-200, which is altogether a heavier combo than mine 5dm2 with 70-200, but the tripod is rated for 13 lbs, so I figured it should work fine.
Once the camera was mounted, you could see visible vibrations for a few seconds.
A light stomp near the camera was causing the camera to vibrate.
Even a delayed shutter made it to vibrate.
D3x - 2 lbs
Nikkor 70-200 - 3.2 lbs
This totals to 5.2 pounds. The tripod and a head are rated for 13.2 lbs. Why does it vibrate?
I've tried Gitzo 1541 legs with the same setup and vibrations were dampened within a second. Yes, I understand this is $600 tripod, but what really do those weight ratings mean?
I have also tested Benro C0190T, which is CF and also rated for 13.2 lbs, but mounting 5D with fairly light 50L would it cause it to vibrate like crazy.
In comparison, my old aluminum Induro (rated at 9 lbs) handled mounted 5D with 70-200 just fine with virtually no vibrations.
So, what's the deal here - the stated supported weight doesn't take vibrations into the account?
Does it mean, I won't be happy until I get Gitzo, because all other travel tripod aren't capable?
