FORUMS Photo Sharing & Visual Enjoyment Sports
Thread started 13 Aug 2012 (Monday) 20:46
Focus Question - Please Help!!!
Pipernails
Aug 13, 2012 20:46 |  #1
Hello,
I had some focus/tracking issues earlier this year and with football season fast approaching, I'm hoping the Canon community can help me.
In a nutshell, I shot youth lacrosse and baseball and noticed the focus often shifted away from the center AF point, usually to the left. I've attached a couple of photos to illustrate. It might be difficult to make out, but the player to the left is in focus and the player in the center is a soft focus.
Here are the settings I used:
Canon Mark III 1D with 70-200mm f2.8L
Manual (sometimes AV or TV depending on conditions), AI Servo, Rear Button Focus, Center AF point (most of the time) with inner 9 points assist.
C. Fn III (Moved AI Servo Tracking Sensitivity to the left)
C. Fn III (AF priority/Tracking Priority)
C. Fn III (4:1 Continuous AF Track Priority)
C. Fn III (8:2 Enable - Surrounding Assist Point)
C. Fn III (9:1 Inner 9 points)
C. Fn IV (1:3 AE lock/metering + AF Start
C. Fn IV (2:1 AF-ON/AE lock button switch - Enable)
I know with a single AF point and a narrow DOF, there is a good chance that some of my shots won't be spot on. That being said, is there something I should be doing differently?
Should I continue to use the surrounding assist points?
Should I continue to use the Inner 9 points?
What is the advantage of using the Inner 9 versus others?
What would you recommend for shooting football?
Any advice would be greatly appreciated!
Thanks so much,
Laura
ajaffe
Aug 14, 2012 18:27 |  #2
For Lacrosse I would use only single point with no assist. The reason being that the action takes place with lots of moving players with moving parts. All of your settings are how I shoot sports with my 1DmkIII.
The two photos you posted have players on different focal planes. Unless you stop down your aperture size you will not get the surrounding players in focus if they are not in the same focal plane as your target.
www.aaronsjaffe.com (external link)
cstewart
Aug 14, 2012 19:07 |  #3
Quick thoughts. Don't use the 9 point assist, go to no assist or surrounding points only. Also use bigger DOF to get more in focus.
Please Check Out My Work at:
Independent Sports News (external link) -- Sports Shooter (external link) --Web Site (external link) -- Facebook (external link) -- iStockphoto.com (external link)--Twitter (external link)
Gear: 1DX; 1D4; 70D gripped; 40D gripped; ; EFS10-22; EFS 17-55; EF 16-35; EF 135; EF 70-200 II; EF 300; EF 1.4X II Extender, 580 EX II Flash
watt100
Aug 14, 2012 19:08 |  #4
ajaffe wrote in post #14859024 (external link)
I agree, check the DOF
http://www.dofmaster.c​om/dofjs.html (external link)
if you want a sharper pic for a group of players (even though you focus on one player), you will need to use a higher (smaller) aperture
e.g.
random group lacrosse pic
XSi (450D)
Canon 100-400
F6.3
200mm
1/1250
IMAGE: http://farm8.staticflickr.com/7056/6938120767_2eaeb491c8_z.jpg
PhotoGeek
Aug 16, 2012 14:47 |  #5
I've been using center AF point only for about 4+ years with pretty good results with the 1dIII.
Remember, if the players are changing direction rapidly or decel/accelerating quickly, the camera may have difficulty keeping focus constantly. It sometimes helps to "pump" the focus button, obtain focus and then wait a second to start shooting.
1DX, 1DIII, lenses, flashes, wires and stuff
http://jimlanterphotog​raphy.com (external link)
1,131 views & 0 likes for this thread
Latest registered member is bushpilot
721 guests, 310 members online
