Thread started 14 Aug 2012 (Tuesday) 06:00
Larger hoods for the 50/1.8 plastic fantastic?
gigolo
Joined Apr 2012
Aug 14, 2012 06:00 |  #1
I've got the 50/1.8 II nifty fifty or plastic fantastic and the ES-62 hood (on the 62L adapter) but I need a larger hood. What options do I have?
macroimage
Aug 14, 2012 06:25 |  #2
gigolo wrote in post #14856174 (external link)
The ET-62 and ET-62II hoods will also fit on the 62L adapter and they are much deeper.
Photo Gear
ed ­ rader
"I am not the final word"
Aug 14, 2012 10:46 as a reply to  @ macroimage's post |  #3
plastic fantastic = tokina 19-35
5D4, 80d, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, sigma 15 FE, sigma 14 f1.8 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
RDKirk
Adorama says I'm "packed."
Joined May 2004
Aug 14, 2012 11:04 |  #4
Why do you need a larger hood? The elements are set so deeply into that lens anyway that you barely need a hood at all for light shielding.
crn3371
Aug 14, 2012 11:11 |  #5
I'd also think that a larger hood could lead to vignetting.
msowsun
"approx 8mm"
Gallery: 18 photos
Aug 14, 2012 12:56 |  #6
The ET-62 will not vignette on a 50mm 1.8 if it is used on a crop camera. It may even be Okay on a Full Frame because it is so wide in diameter.
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Photo9/001aa-7.jpg
Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
macroimage
Aug 15, 2012 03:04 |  #7
Here is how it looks on my 5D. It doesn't seem to vignette even on full frame. It also fits on reversed for storage.
Photo Gear
sandpiper
Aug 15, 2012 04:02 |  #8
RDKirk wrote in post #14860625 (external link)
Ah, I found a picture. The Kodak stainless steel "rapid" processing drum:
http://www.photomemora​bilia.co.uk …Rapid_Drum_Proc​essors.jpg (external link)
The drum was smoothly dimpled and spun at high speed. Chemistry went into the tray below the drum. When the drum was set spinning, it carried a thin layer of chemistry on its dimpled surface. The tray was on gimbals, so you could tip it to empty one chemical and pour in the next as you processed the paper.
The exposed, unprocessed print paper hydroplaned on top of that thin layer, held by the fabric mesh. But you had to set the paper on it--while the drum was spinning--in total darkness. As I said before, if you got it wrong, the drum spat that $5.00 sheet of paper (in 1970 dollars) against the opposite wall.
It took a learned knack...that is unnecessary today.
Are you suggesting using a processing drum as a hood?
I think you may have wandered in through the wrong door :lol:
It might help people think of options, if they knew what you are trying to achieve. I can understand the desire for a larger hood than standard if using an EF lens on a crop camera, as the matched hood is designed to allow FF coverage. But you are using a FF camera, so the hood designed for that lens should be perfect, and you have already got one larger than that. We really need to know the objective here, to give a sensible recommendation.
1,581 views & 0 likes for this thread
Latest registered member is IamCrom
529 guests, 229 members online
