Thread started 20 Dec 2005 (Tuesday) 08:57
Photos at 135mm and 200mm?
Samiad
Joined Jul 2004
Dec 20, 2005 08:57 |  #1
I currently own a Canon 28-135mm f/4.5-5.6 IS lens - this is a good lens and I'm reasonably happy with it. It has good points (IS works well) and it has bad points (quite slow aperture, and I would prefer better image quality - in colours and contrast).
The lens represents the longest zoom in my camera bag - 135mm. I am thinking of buying a Canon L 70-200mm f/2.8 IS to get that little bit more range that I need. This seems like a good move as it means I retain IS, and I will also get the fast aperture and higher quality glass.
Can someone help me out and perhaps show a photo taken at 135mm and the same scene taken at 200mm? I don't mind if it's 'knocked' up in photoshop to show the field of view, but real photos would be ideal. Reason being that I am considering other lens that stretch to 300mm. However, as I rarely need much more than 135mm, I would probably be just fine with 200mm.
If I do go for a 70-200, I would probably look to sell the 28-135mm and replace with a higher quality zoom, (24-70?) to stop the overlap.
There's one thing I don't like especially about the 70-200 (and yet I like this at the same time) - it's not subtle. I hope 200mm is long enough to get good candids whilst waving about a 3lb huge lump of white lens in someones direction!
p.s. I would get a 1.4 teleconvertor at the same time as the 70-200mm.
Digital Photography
http://www.samiad.co.u​k/gallery (external link)
Quad
Joined Nov 2005
Dec 20, 2005 09:17 |  #2
1That is a big jump in size as well as quality I suppose. You might want to hold on to your current lens to make sure you don't mind the weight and for those times you need something more discrete. I would not think you would sell it for enough to offset too much of the new lens' cost.
i don't have any telephoto lenses to show you a fov difference but I would not think it would be a huge difference. Enjoy the new lens.
Curtis ­ N
Master Flasher
Dec 20, 2005 09:25 |  #3
I'm not sure if this is what you're looking for, but
You can download this Excel file. (external link)The DOF calculator in it will give you the field of view (width & height) in feet or meters, given the camera format, distance and lens focal length. It might be fun to play with.
Or to put it in simpler terms, 200mm will give you about 2/3 the field of view of 135mm. If you cut a 2 5/8 x 4 inch hole in a piece of paper and put it over a 4 x 6 print, that will give you a pretty good approximation.
RichardtheSane
Joined Jun 2003
Dec 20, 2005 15:28 as a reply to  @ Curtis N's post |  #4
If you have no samples tomorrow I'll snap a couple for you.
And to hurl a spanner in, I wouldn't say that 135mm to 200mm is that much of a significant increase... consider the sigma 100-300 F4..?
If in doubt, I shut up...
Gear: 40D, 12-24mm AT-X Pro, 17-85mm, Sigma 150mm Macro Sigma 100-300 F4, 550EX, other stuff that probably helps me on my way.
Amorous
Dec 20, 2005 19:20 as a reply to  @ RichardtheSane's post |  #5
I don't know if there is any photography store that rents the lenses where you live. In my area, I can rent 70-200mm f/2.8 IS for $35/day. In fact, I'm renting one this Friday to try out at the Disney on Ice show. I can't afford to buy one right now, but I think it's a good investment to try it out before buying an expensive lens.
My web site: http://kaitcilla.smugm​ug.com/ (external link)
Los Angeles area local photography group: http://lashooters.org (external link)
Samiad
Joined Jul 2004
Dec 21, 2005 10:23 |  #6
Thanks,
I think 200mm will be enough for my needs, as I rarely feel the need for much more. I will probably get the 1.4X teleconvertor too for times when it's needed.
To be honest I am more looking forward to the f/2.8 and the IS, those are what I need.
Not looking forward to the weight and the spectacle of a huge white lens though.
There is a place that offers a rental service so I will give that a go.
Digital Photography
condyk
Africa's #1 Tour Guide
Dec 21, 2005 10:40 |  #7
What about the 200mm 2.8 L which is black? Great quality and you can add a TCon and still be at f4. Re. RichardtheSane's suggestion of the Sigma 100-300 f4 ... good one and it is a lovely piece of glass, but a bit heavy and you need a mono to squeeze the last essential 10% out of it, i.e. the difference between good and stellar!
I agree the 28-135 is a bit of an average package ... seems much better in theory than practice, in my experience at least. A good standard zoom would give you light and IQ and you'll have some change from selling the dull IS. You then have a gap to 200mm ... dunno if it would matter. You could pick up a fully MF like my CZJ 135 3.5 with an EOS adaptor for not much cash.
https://photography-on-the.net …/showthread.php​?t=1203740
blue_max
Dec 21, 2005 10:56 as a reply to  @ condyk's post |  #8
As an ex-owner of a 70-200 and an owner of a 135mm prime, I can tell you that I was not too impressed by the increase in magnification between the two extremes. It seems that going up in size makes less and less difference.
Graham
Lamb dressed as mutton.
barrettbonden
Dec 21, 2005 13:44 |  #9
the next lens I will buy is a 135L, at 2.0 you have a better lens for some things and with a , 1,4 adapter it becomes almost 200 at 2.8. That may be a good idea for you. There is also a 2x converter. the 135L is black, very fast focusing (they say), black, and great for candid portrait (they say).
20d | EF 16-35L | EF 85 mm f/1.8 | EF 70-300mm f/4-5.6 IS USM 580EX | manfrotto 3021BPRO | 488RC2 ballhead | slingshot 100AW | compudaypack | rollling computrekker AW plus
http://www.vicentedepa​blo.com (external link)
Bookmarks
Dec 23, 2005 15:10 as a reply to  @ barrettbonden's post |  #10
Here are 2 photos shot at 135mm and 200mm. The setting was f/11 and 1/200 sec for both pictures. The 135mm was shot with the EF 28-135mm f/3.5-5.6 IS USM on tripod with IS off. The 200mm was shot with EF 200mm f/2.8L II USM on tripod.
135mm 1/200 @ f/11 EF 28-135mm f/3.5-5.6 IS USM
200mm 1/200 @ f/11 EF 200mmL II USM
The pictures were autocontrasted in PS but the colors were not altered. The 135mm lens is a bit warmer in color than the 200mm.
hjoe
J ­ Rabin
Joined Aug 2004
Dec 23, 2005 17:40 as a reply to  @ Bookmarks's post |  #11
Canon has done this for years on their websites. Go here:
http://consumer.usa.ca​non.com …tIndexAct&fcate​goryid=150 (external link)
Then click on "lenses 101" button right side of screen, the click focal length comparison.
Wavy ­ C
Joined Jan 2005
Dec 23, 2005 17:42 |  #12
Nice example hjoe. Not a lot of difference at all. Funny, I would have expected to see more.
It wasn't me!
guitarman
Joined Jun 2005
Dec 23, 2005 17:48 as a reply to  @ Wavy C's post |  #13
This was taken with the 70-200mm F2.8 IS @ 200mm. I was in the back of a boat being thrown all over the place so its not quite as sharp as it could have been.
Terry
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Dec 23, 2005 19:25 as a reply to  @ condyk's post |  #14
I would second the 200 f2.8 L. Much sharper than the 70-200, lighter, and it is black so it is less conspicuous. I use a 1.4 X T-Con on it and you can hardly tell the difference in picture quality. With the T-Con the picture quality still surpasses the 70-200 (any of the 3).
Doc Klepper in the USA
I
rklepper
Joined Dec 2003
Dec 23, 2005 19:26 |  #15
Oh, and the 200 f2.8 L is also costs much less than either of the 70-200 f2.8's.
I
2,913 views & 0 likes for this thread, 14 members have posted to it.
1995 guests, 126 members online
