I've been ok up to now with the OE Canon strap on my T3i. However in the last week I've gotten a new 24-105 and a 430EX flash. I'm also planning on getting a grip to balance things out some as well as to make the camera a bit easier to hold.
Anyway, the OE strap and me using the kit lens would bug me at times depending on how it sat on my neck. It is also not long enough to allow me to put it on one shoulder and have the camera on the opposite side under my arm. (like a woman's purse) The problem I see now is that the new combo of flash plus lens and possibly even grip is going to kill my neck if I keep using the OE strap.
So, I need suggestions as to what strap you guys use. It would need to be padded and I really don't care if it holds the top or bottom of the camera. Though after reading some of the posts about the blackrapid strap here I am hesitant to hang the camera by a single clip. Thanks in advance.
FWIW I already have a backpack to carry my stuff in but I need something specifically for shoulder/neck carry. (is the canon CPS strap longer than the standard ones you get with the cameras) Thanks in advance.
I wound up ordering the OP/TECH Pro Strap plus a sling adapter as well as some extensions. The price plus versatility and ability to add on extensions and other items was a huge plus. I'm sure this will make the camera a lot more comfortable to carry around than it was with the OE strap.
