I guess so... is it just for bright sunlight? I presume that if you shoot someone in the shadow, your ISO will rocket up...
Is Kenko filters ok?
Earwax69 Goldmember 1,044 posts Likes: 4 Joined Jul 2012 More info | Aug 16, 2012 21:33 | #1 I guess so... is it just for bright sunlight? I presume that if you shoot someone in the shadow, your ISO will rocket up... Canon 6D | S35mm f1.4 | 135mm f2 The rest: T3i, 20D, 15mm f2.8, 15-85mm, 24mm f2.8, 50mm f1.8, 85mm f1.8, 90mm f2.8 macro, 55-250mm.
Mark-B Goldmember 2,248 posts Likes: 10 Joined Jul 2007 Location: Louisiana More info | Aug 16, 2012 21:44 | #2 In full sunlight during the middle of the day, it is very possible to have overexposed images at f/1.8. A 3 stop ND filter would be enough to take care of this. Mark-B
Aug 16, 2012 22:31 | #4 Max shutter speed is 1/4000. T3i. Canon 6D | S35mm f1.4 | 135mm f2 The rest: T3i, 20D, 15mm f2.8, 15-85mm, 24mm f2.8, 50mm f1.8, 85mm f1.8, 90mm f2.8 macro, 55-250mm.
What mode are you shooting in, ie AV, P, TV, green square? And what ISO? Auto ISO? Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
1Tanker Goldmember 4,470 posts Likes: 8 Joined Jan 2011 Location: Swaying to the Symphony of Destruction More info | Aug 17, 2012 00:47 | #6 Earwax69 wrote in post #14868836 Max shutter speed is 1/4000. T3i. I've just tried it and this I dont understand: In the sunlight, the 4000 blink until f2.8. However the camera take the photo anyway at f1.8. The picture look fine in the LCD. At 2.8, the 4000 stop blinking and the photo look identical to the f1.8 except for the DoF. Will I have a bad surprise when I check the RAW file? The shot at 1.8 will have some blown highlights, for sure. The difference between 2.8 and 1.8 is only 1-1/3 stop; the highlight flashing on the LCD, can start on a surprisingly well exposed shot, so you have some leeway. For best results though, ISO 100, 1/4000, and/or a 3-stop ND. You can bring down some of the highlights in post as well. Kel
Aug 17, 2012 00:47 | #7 Yes, generally auto ISO except when I do macro. Mode is AV or TV, depending on the situation. Canon 6D | S35mm f1.4 | 135mm f2 The rest: T3i, 20D, 15mm f2.8, 15-85mm, 24mm f2.8, 50mm f1.8, 85mm f1.8, 90mm f2.8 macro, 55-250mm.
Aug 17, 2012 02:00 | #9 Mmm... I dont follow you. 1/4000 at f2.8 was perfectly exposed. That was the maximum opening I could go before the numbers start blinking. At f1.8, (the desired aperture), the blinking indicated that it was wrong. Canon 6D | S35mm f1.4 | 135mm f2 The rest: T3i, 20D, 15mm f2.8, 15-85mm, 24mm f2.8, 50mm f1.8, 85mm f1.8, 90mm f2.8 macro, 55-250mm.
1Tanker Goldmember 4,470 posts Likes: 8 Joined Jan 2011 Location: Swaying to the Symphony of Destruction More info | Aug 17, 2012 03:38 | #10 Earwax69 wrote in post #14869324 Mmm... I dont follow you. 1/4000 at f2.8 was perfectly exposed. That was the maximum opening I could go before the numbers start blinking. At f1.8, (the desired aperture), the blinking indicated that it was wrong. That mean that yes, I need a 3-stop ND filter if I want to use f1.8 in bright sunlight at ISO 100. It's around 20$ on amazon for 58mm size. I would stick with a well respected brand.. such as B+W or Hoya. Be prepared to spend much more than $20..more like, over $50. Kel
Aug 17, 2012 03:57 | #11 Kenko is Hoya. Same product, Kenko in Japan, Hoya in other countries. Canon 6D | S35mm f1.4 | 135mm f2 The rest: T3i, 20D, 15mm f2.8, 15-85mm, 24mm f2.8, 50mm f1.8, 85mm f1.8, 90mm f2.8 macro, 55-250mm.
1Tanker Goldmember 4,470 posts Likes: 8 Joined Jan 2011 Location: Swaying to the Symphony of Destruction More info | ^Zeiss is made by Cosina,,but that doesn't mean the Zeiss lenses are using Cosina-specs. Kel
Aug 17, 2012 04:51 | #13 Mmm yeah. I've been reading a bit and Kenko bought Hoya a while ago. Kenko filters are everywhere in Japan and got good enough reviews on amazon. However you might be right. I'll check for B+W filters. Canon 6D | S35mm f1.4 | 135mm f2 The rest: T3i, 20D, 15mm f2.8, 15-85mm, 24mm f2.8, 50mm f1.8, 85mm f1.8, 90mm f2.8 macro, 55-250mm.
| Latest registered member was a spammer, and banned as such! 2886 guests, 156 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
