Thread started 20 Dec 2005 (Tuesday) 14:32
CS2 Upgrade - Maybe / Maybe Not.....?
Mark_48
Dec 20, 2005 14:32 |  #1
One of my other pastimes besides photography is weekend yardsales. Recently I bought a box of old computer hardware and software for $10. I hadn't really gone through it until this past weekend. In the box was an original CD-ROM in its jewel case, of Adobe Photoshop 3.0 with the serial number included. I installed on an old Win98 machine I had just to be sure it was good and in working order.
Now I'm thinking maybe I should be able to upgrade to CS2 since Adobes site states any version of PS can be used for the upgrade and all that is needed is the serial number from the previous version.
What I'm not sure of is if I might run into any problems if the software may have been previously registered, which I have no way of knowing. Would Adobe possibly needed further proof that I have "purchased" and in possession of the original CD and serial number ?
If it's too good to be true, it probably is:rolleyes:
Megapixels and high ISO are a digital photographers heroin. Once you have a little, you just want more and more. It doesn't stop until your bank account is run dry.
Dchemist
Joined Sep 2003
Dec 20, 2005 15:07 |  #2
When I did this (upgrade) you needed a later version -- I believe it was version 5 or newer in order to qualify for a CS upgrade. Otherwise it worked fine. You will need to check closely with Adobe on this as my information is a year old. Also, I believe you only needed a valid Serial number of the old version.
Dennis
POTN Book Vol4 Astronomy Image Manager and BC Member
20D, 5DMkII, 50F1.4, 100F2.8 macro, 135F2, 17-40F4, 70-200F2.8, 24-105F4, 580EX
In2Photos
Dec 29, 2005 08:32 as a reply to  @ Dchemist's post |  #3
Dennis
Sorry to bring up an old thread but I have PS6 with a valid serial number I think. How can I tell if it is valid? I got it from a college friend several years ago and never installed it before but came across it the other day. If I can get PS CS2 for $150 vs PSE4 for $80 I will go the CS2 route. However, I don't want to throw away $150 for CS2 upgrade if I can't upgrade. Any Thoughts?
Current Gear and Feedback
Mark_48
Dec 29, 2005 08:55 as a reply to  @ In2Photos's post |  #4
Just for the heck of it go to Adobe's site and see if you can register it. I tried this with the V3.0 I have and it said it didn't recognize the number and to contact customer service which I plan doing. If the software has been registered previously this may be a way of finding out. If your copy registers online I would think you'd be good to go. I don't know if previous owners of software have to "unregister" it to make it useable for others that came into its possession.
https://store.adobe.co​m …Objects/WEC?pag​eID=RegMp1 (external link)
spencer87
Dec 29, 2005 09:00 |  #5
any version (even 1.0) is eligible for an upgrade to CS2. If you are upgrading from version 5 or earlier, you will need to call customer service so they can walk you through the upgrade installation. cheers!
S
In2Photos
Dec 29, 2005 09:11 as a reply to  @ spencer87's post |  #6
Thanks guys, I will give it a try when I get home to see if I can register my copy of PS6. If so, CS2 will be on order.:lol: Along with one of Kelby's books so I know what the h**l I am doing.:lol:
In2Photos
Dec 29, 2005 13:10 as a reply to  @ Mark_48's post |  #7
When I go to their site I get this error:
Error! .An exception has occurred: java.lang.NullPointerE​xception
Any ideas? Do I need to call Adobe?
Mark_48
Dec 29, 2005 13:35 as a reply to  @ In2Photos's post |  #8
Maybe my browser handles the link differently. If you go to Adobes site http://www.adobe.com/ (external link) , click the tab for Purchase and then Customer Service. A menu to select product registration will show. Follow that and see what happens.
In2Photos
Dec 29, 2005 13:41 as a reply to  @ Mark_48's post |  #9
Sorry, I didn't explain that very well. I tried to send in the information and the error is what I received after pressing the continue button. What now?
Mark_48
Dec 29, 2005 13:51 as a reply to  @ In2Photos's post |  #10
Can't help on the error. I tried entering a number and it kicks back an error stating the number is in error - not a java error. You'll probably end up calling like I'll do. Adobe - (800)833-6687
2005GLI
Dec 29, 2005 14:47 as a reply to  @ Mark_48's post |  #11
I just tried to enter my serial # from ps7 and its 1 set of #'s short for cs2. i have 5 sets vs. 6 for cs2. I may try my elements 2.0 #'s for the 4.0 upgrade.
|Canon 80D|40D backup|24-105 F4/L|Sigma 70-200 F/2.8|Sigma 150-500 C|
|Tokina 12-24|Sigma 8mm Fisheye|
In2Photos
Dec 29, 2005 15:07 as a reply to  @ 2005GLI's post |  #12
Are you using the CD key instead of the serial number perhaps?
Mark_48
Dec 29, 2005 15:13 as a reply to  @ 2005GLI's post |  #13
I think I lost you on this. Are you saying that of the serial number, of the blocks of 4 numbers, that you only have 5 blocks rather than 6 ?
1------2-----3------4-----5------6
1234 5678 9012 3456 7890 1234
In a thread somewhere I think you can get the full serial number from the drop down help menu in the PS program, if that helps.
Mark_48
Dec 29, 2005 16:12 as a reply to  @ Mark_48's post |  #14
I just got off the phone with Adobe. The rep assured me there would be no problem using PS V3.0 upgrading to CS2. He checked the serial number and it is registered to someone other than myself, but as he stated this only affects tech support for the V3.0 product and not an upgrade. He further stated if I needed the support for V3.0 I could contact the original licensee and have a license transfer done, which ain't likely as I probably wouldn't be able to find the original owner/licensee. Can't envision needing tech support for something I probably wouldn't use:rolleyes:. The Adobe rep said I'd have to call in the V3.0 serial number as it was an old one and not recognized by newer software.
Anyhow I head to Newegg to see what they get for a CS2 Upgrade package. I notice in the reviews someone that is not particularly happy with Adobe. Only lends to further skepticism about an upgrade. Makes me think it would be best to purchase directly from Adobe to avoid issues of trying to return opened software if the upgrade can't be done.
"Beware Older Versions
Pros: Should be a great product and is a great price....
Cons: Will not load on my system. I have Photoshop 5.0 running on Windows XP Pro and when I go to load it I get a message:
"Can't find your version of Photoshop 5.5 or higher". That wasn't on the package... More »
or on this spec sheet. It reads:
"To install this upgrade successfully, you will need a licensed version of Adobe Photoshop CS or Adobe Photoshop 7.0 or earlier, on the same platform as this purchase." To my understanding 5.0 is earlier than 7.0. Don't even think of trying to contact Adobe. I sent numerous emails. They are far too important to talk to their customers!!!
Other Thoughts: Maybe a class action suit might help. Face it the package says:
"This upgarde version will install only if you are a licensed user of a previous version of this software product". I don't see 5.5 or higher in the text, do you?
NewEgg is still great, Adobe marketing lacks.
Reviewed By: N/A, 12/13/2005 6:13:06 PM
This reviewer reports that his/her technical understanding of this type of product is somewhat high and has owned this product between 1 month to 1 year.
4 out of 8 people found this review helpful. Did you? "
In2Photos
Dec 29, 2005 16:44 as a reply to  @ Mark_48's post |  #15
Mark. please keep us informed on your progression. I got disconnected earlier from Adobe and didn't get achance to call them back. Good luck.
1,944 views & 0 likes for this thread, 6 members have posted to it.
2304 guests, 135 members online
