Canon Ef-s 18-135 3.5-5.6 Is
i am sortta looking to get a good used lens that in between of what i already have..is this a wide angle lens?
i have the Cannon 70-200 4L
cannon 50mm 1:1.8 II
cannon 18-55mm ( kit lens)
Quantary 70mm-300 w/macro
photocopy Goldmember 1,555 posts Likes: 2 Joined Nov 2011 Location: PNW More info | Aug 17, 2012 10:51 | #1 Canon Ef-s 18-135 3.5-5.6 Is
Aug 17, 2012 10:56 | #2 Depends on what you consider good. You have the 70-200L so you know what good looks like.
DreDaze happy with myself for not saying anything stupid More info | Aug 17, 2012 14:24 | #3 it'll have the same angle as your kit lens...and then go longer to 135mm...but the wide-angle will be the same at 18mm Andre or Dre
ScottM Goldmember More info | Aug 17, 2012 15:59 | #5 You probably will not notice any improved image quality over your kit lens -- only a greater focal range.
wayne.robbins Goldmember 2,062 posts Joined Nov 2010 More info | Aug 17, 2012 16:18 | #6 It's a decent enough lens- if priced right. An improvement in IQ- not really- probably more of a lateral upgrade- if you find yourself swapping lenses a lot and don't want to- then the 18-135 has that in its favor. IMO, the 18-135 really represents a newer generation of walk about lenses for crops- a general purpose one lens solution in lieu of carrying two separate lenses to cover the same typical range. From what I've seen previously in the for sale forums- in the $200 ~$250 range for used. The new 18-135 IS STM has better IQ.. From what I've read- the 18-135 IS- the lens you are talking about- has better IQ than the 28-135 USM plus it goes wider- to 18. EOS 5D III, EOS 7D,EOS Rebel T4i, Canon 70-200 f/2.8 IS II, Canon 24-105L, Canon 18-135 IS STM, 1.4x TC III, 2.0x TC III, Σ 50mm f/1.4, Σ 17-50 OS, Σ 70-200 OS, Σ 50-500 OS, Σ 1.4x TC, Σ 2.0x TC, 580EXII(3), Canon SX-40, Canon S100
| Latest registered member is semonsters 1021 guests, 106 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
