So reading a bit about the mk111 and I saw something about the auto focus and using teleconverters, not being useable past F 8.
Anybody have anymore info on this???
Sgt. Senior Member More info | Aug 17, 2012 18:48 | #1 So reading a bit about the mk111 and I saw something about the auto focus and using teleconverters, not being useable past F 8. Iain
Aug 17, 2012 19:05 | #2 This is only the case when the converter (either the 1.4x or 2x) adds one or two stops and the maximum aperature and it ends up greater than f8 Chris -- Gear List
Christina.DazzleByDesign Goldmember 1,973 posts Likes: 6 Joined Mar 2012 More info | Aug 17, 2012 20:40 | #3 |
EchoJohnson Senior Member 433 posts Joined Aug 2011 Location: UK More info | Aug 17, 2012 20:58 | #4 My 5D Mark III can't meter beyond f/8. You'd think that 108 generations later Canon would have improved that. Canon 5D3 | 17-40 | 50/1.4 | 135/2
umphotography grabbing their Johnson More info | Great Camera.....Dumb move on Canons part. Mike
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Aug 17, 2012 21:24 | #6 Christina.DazzleByDesign wrote in post #14872620 And thats not just the 5D3, its any DLSR that isn't a 1D series body - I believe ![]() same with 1dx. 1dmk4 is the last body with AF at f8. Fuji XT-1, 18-55mm
Christina.DazzleByDesign Goldmember 1,973 posts Likes: 6 Joined Mar 2012 More info | Aug 17, 2012 21:28 | #7 bobbyz wrote in post #14872751 same with 1dx. 1dmk4 is the last body with AF at f8.
5D3 | 7D | 85L II | 70-300L | 24-105L | Nifty Fifty | 600EX-RT_______________
YogiBear Goldmember 1,492 posts Likes: 3 Joined Feb 2009 Location: League City, TX USA (Houston) More info | Aug 18, 2012 15:27 | #8 Silverstonev8 wrote in post #14872376 This is only the case when the converter (either the 1.4x or 2x) adds one or two stops and the maximum aperature and it ends up greater than f8 It will still focus past f8 just not if the lens converter combo limits the maximum aperature smaller than f8. I believe it is possible to tape over the contacts to retain AF but not sure about that. Don't you mean "smaller than f/5.6"? It won't AF at f/8, at least not according to Canon specs. Canon EOS 7D | EF-S 17-55mm f/2.8 IS USM | EF-S 55-250mm f/4.0-5.6 IS |
wayne.robbins Goldmember 2,062 posts Joined Nov 2010 More info | Aug 19, 2012 13:03 | #9 Expecting it to AF correctly - beyond f/5.6 for any non 1D series- is, well, expecting too much- you are pushing it beyond specs. Tape trick works - SOMETIMES- and won't necessarily be a fast autofocus- not for fast action. Tape trick = YMMV or should it be YMWV ! You can focus beyond 5.6 with a TC- albeit slowly- using Liveview and either manual focus at 10x or sometimes autofocus by itself.. Different lenses with different TC's will end up with different truth tables- a definite case of Your Mileage Will Vary !. EOS 5D III, EOS 7D,EOS Rebel T4i, Canon 70-200 f/2.8 IS II, Canon 24-105L, Canon 18-135 IS STM, 1.4x TC III, 2.0x TC III, Σ 50mm f/1.4, Σ 17-50 OS, Σ 70-200 OS, Σ 50-500 OS, Σ 1.4x TC, Σ 2.0x TC, 580EXII(3), Canon SX-40, Canon S100
NASSPhoto Goldmember 2,478 posts Likes: 899 Joined Jun 2009 Location: Westmoreland Co., PA More info | Aug 19, 2012 15:10 | #10 Echo Johnson wrote in post #14872674 My 5D Mark III can't meter beyond f/8. You'd think that 108 generations later Canon would have improved that. funny. I guess that I am 109 generations behind. If, I ever get a canon body that does not work w/ f/8.0, I will have to do my best w/ my 400mm f/5.6. NickS
pwm2 "Sorry for being a noob" 8,626 posts Likes: 3 Joined May 2007 Location: Sweden More info | Aug 19, 2012 15:38 | #11 Christina.DazzleByDesign wrote in post #14872764 oh really? I didn't know that.. Why wouldn't they do it for their "flagship" camera?Maybe because as they increase the resolution of the sensor, they need the focus system to be even more exact. After all, DoF isn't something absolute but is a question of what distance range that is "sharp enough". 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
| Latest registered member is semonsters 922 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
