Colour Space Confusion
Hi I’m looking for some help to understand what is happening on my PC with Ph’s colour space. CS5
Firstly I use a 5dmkii which is set to sRGB on the camera. I then use a cable to get them onto my PC.
Opening these photos in any other program (I use Irfanview) the images look fine right out of the camera. If I then bring them into Ph straight away the colours look wrong with very strong reds. If I then make adjustments to the colours in Ph and save that file when I open it in others programs it looks horribly washed out and the same carries right through to the printer.
In the colour settings box I have set my colour space to the richer Adobe (RGB) 1998 but I get the same results with sRGB IEC61966-2.1
Do you know why am I getting this colour change and how do I get Ph set correctly so what I see on the screen is what comes out of my printer and on the web is as I need it to be. Right now I just can’t use Ph as it is.
I've done a lot of reading about this and have many links explaining how to set colour space but my issue above doesn't seem to include any solution to this isssue.
Thanks!
