Thread started 20 Aug 2012 (Monday) 08:20
60D question
ldgary
Joined Jul 2012
Aug 20, 2012 08:20 |  #1
Yesterday I was trying to take some photos of my friends hummingbirds. I had the camera set in manual mode. I coul not get the shutter speed to get higher than 1/250. Needless to say my photos did not stop wing action.
My camera was purchased 3 weeks ago through the CLP. I am going to test some more this evening to see if I can duplicate the problem. I didn't have time yesterday as I had to return home from my trip.
Thanks for any tips.
Leisa
Canon 60D, 28-135, 18-200 lenses.
msowsun
"approx 8mm"
Gallery: 18 photos
Aug 20, 2012 08:27 |  #2
Did you have the flash turned on? Flash will limit the shutter speed to 1/250.
ldgary
Joined Jul 2012
Aug 20, 2012 08:52 |  #3
I don't think I had the flash turned on but I may have. I am still learning this camera so that's something I will check this evening when I try to take more photos.
Leisa
Bob ­ Sherwood
Joined Oct 2004
Aug 20, 2012 08:58 as a reply to  @ ldgary's post |  #4
Try a higher ISO and shutter priority to stop the action.
mrbtd
Aug 20, 2012 12:02 |  #5
Also safety shift may be on. The camera overrides what you tell it if it senses under exposure.
msowsun
"approx 8mm"
Gallery: 18 photos
Aug 20, 2012 12:04 |  #6
mrbtd wrote in post #14882442 (external link)
The OP was in Manual mode. There is no safety shift in Manual mode.
ScullenCrossBones
Aug 20, 2012 12:15 |  #7
Could the quick control dial be locked? Just a thought.
:p Gear
Mama done took my Kodachrome away...
ldgary
Joined Jul 2012
Aug 20, 2012 12:18 |  #8
I had gone up to ISO 3200. I was in full manual mode. I do not remember if I had the flash off. It was mid morning. Not direct sunlight but slight overcast.
Leisa
TSchrief
Joined Aug 2012
Aug 20, 2012 13:35 |  #9
I leave my flashes, 430EX II and 550EX, is HSS (High-Speed Sync) mode to avoid such shenanigans. You can use 1/8000 with HSS enabled. Granted, the range is extremely limited, but at least the shutter fires.
ldgary
Joined Jul 2012
Aug 20, 2012 14:21 |  #10
I guess I should clarify. The only flash I have right now is the one built on the camera.
Leisa
TSchrief
Joined Aug 2012
Aug 20, 2012 14:29 |  #11
ldgary wrote in post #14883017 (external link)
Ok. Then HSS does not apply. It is curious that your shutter speed was limited to 1/250. That is the shutter speed limit with the built-in flash popped up.
Edit: One thing that comes to mind: your camera may "think" an external flash is attached. There is a small metal strip on the right side of the hot-shoe that activates a switch to tell the camera a flash is attached. If the metal strip is down, the switch is pressed, and the camera thinks there is a flash attached. You can usually dislodge the metal strip with a tooth-pick or something similar. See a photo of the strip/switch at:
http://www.flickr.com/​photos/dougpardee/1330​66175/ (external link)
ScullenCrossBones
Aug 20, 2012 15:37 |  #12
You should be able to fire the shutter at any shutter speed if you are in manual mode, regardless of whether or not a flash is connected (or the camera thinks one is).
:p Gear
TSchrief
Joined Aug 2012
Aug 20, 2012 15:45 |  #13
ScullenCrossBones wrote in post #14883399 (external link)
This is simply incorrect. Shooting mode has nothing to do with flash sync. If the on-board flash is up, or there is an external flash attached (and turned on), the shutter speed is limited to the camera's maximum flash-sync speed. On the 500D it is limited to 1/200. On the 60D it is limited to 1/250. The ONLY way to get around this is to set the external (built-in can't do this) flash unit to HSS. This is true for ALL shooting modes.
msowsun
"approx 8mm"
Gallery: 18 photos
Aug 20, 2012 15:58 |  #14
TSchrief wrote in post #14883432 (external link)
You are only limited to flash sync speed with Canon compatible flashes. Also known as "Dedicated" flash. With a non-Dedicated flash you could set a shutter speed higher than the camera's flash sync speed. But in that case you would see a dark band at the bottom of the photo from having a shutter speed higher than the camera's sync speed.
I just tried an old school, non-dedicated flash on my 7D and 5D Mk II, and both were able to set a shutter speed much higher than the camera's sync speed.
John ­ from ­ PA
Joined May 2003
Aug 20, 2012 16:04 |  #15
Like TSchrief stated look carefully at the hot shoe to see if that small switch is sending a signal to the camera making it think a flash is mounted.
At ISO = 3200 the basic exposure for bright sun would have been f/16 at 1/3200 sec. Even slight overcast as you mention would have yielded a stop more; perhaps 1/3200 sec at f/11. I would have thought that any of the pictures you took at ISO 3200 and where the shutter was limited to 1/250 would have been terribly blown out (over exposed).
Can you post a picture here with EXIF attached? We might be able to tell more what is going on. For one thing the EXIF will clearly indicate if a flash was attached (even if it wasn't).
By the way, you likely will not perfectly freeze the wings of a hummer solely with the capability of the 60D. To freeze all motion in a hummingbird's wings, you need a shutter speed of 1/5,000 to 1/20,000 of a second. Having said that, I think that sometimes the slower end, which the 60D can do, the lsight evident motion improves the shot.
Go to http://www.rpphoto.com​/howto/hummer/humguide​1.asp (external link) for some good tips on "hummer" photography.
3,070 views & 0 likes for this thread, 11 members have posted to it and it is followed by 2 members.
60D question
694 guests, 125 members online
