Thread started 20 Aug 2012 (Monday) 14:51
Foot for Canon 400 2.8 IS
huntersdad
Aug 20, 2012 14:51 |  #1
I just picked up a Canon 400 2.8 IS. Right now, I am planning to use it with a Winberley Sidekick mounted on a Vanguard head. I was going to pick up a Wimberley plate for the lens, but they don't make one - only the replacement foot, which renders the foot useless for carrying.
I know RRS makes a replacement foot and plate, but I'm not sure if it is truly compatible with the Sidekick.
Any other options?
Facebook (external link)
http://WWW.BLENDEDLIGH​TPHOTOGRAPHY.COM (external link)
1DxIII x 2 / 24 1.4 II / Sigma 35 1.4 / 85 1.4L / 70-200L II / 300 II / AD600Pros
johnf3f
Aug 20, 2012 18:40 |  #2
Any of the replacement feet (from the top manufacturers) are designed to be Arca compatible so should fit fine. If you are uncertain contact Wimberley - they are VERY helpful.
Just a thought, I use the 600 F4 IS (about the same weight) on a Wimberley 2 with the original foot and this setup is superb. I didn't go for the Sidekick as I wasn't certain it was fully up to the job, again I would check it's suitable and check whether you need a new foot for your 400.
Selling your Sidekick and not buying a new foot would go a long way to covering a Wimberley 2 - Just a thought.
Have a look here http://www.tripodhead.​com …idekick-compatibility.cfm (external link)
Life is for living, cameras are to capture it (one day I will learn how!).
huntersdad
Aug 20, 2012 19:11 |  #3
Haven't really thought about it that way, but I think even with a Gimbal, I need a A/S foot or plate of some sort to mount the lens. I guess most of them probably come with one for use.
MDJAK
Aug 20, 2012 20:27 |  #4
I had a RRS replacement low profile foot for my 200 f2 as I couldn't reverse the hood with the original food. It worked perfectly on my sidekick, for whatever that's worth.
bobbyz
Aug 20, 2012 22:52 |  #5
does naturescapes.net have a foor for 400mm f2.8? I had one for 500mm f4 and it was nice. Only issue was when hand holding with that low profile foot.
Fuji XT-1, 18-55mm
johnf3f
Aug 31, 2012 10:59 |  #6
huntersdad wrote in post #14884341 (external link)
Forgot to mention I had a pre IS 400 F2.8 - that didn't need a replacement foot to balance on the Wimberley 2. You will need a quick release plate, but they can be quite cheap. I have QR plates from Kirk, Wimberley, Sirui and a number of other Chinese makers - all are absolutely fine.
1,763 views & 0 likes for this thread, 4 members have posted to it.
2594 guests, 161 members online
