Thread started 21 Dec 2005 (Wednesday) 00:36
Landscape EF-S lens
weka2000
Is that a 300mm in your pocket?
Gallery: 145 photos
Dec 21, 2005 00:36 |  #1
EF-S 10-22 and EF-s 17-85 IS. Those people that have 1 of these or both could you place feedback as to their quality for doing landscape photos and waterfalls. I have a EF-S 18-55 kit lens and Sigma 50-500 and in the last week had the loan of a 16-35mm F2.8 and 17-40 F4 both "L".
For basically the same price of a 16-35 F2.8 I could get the 2 EF-S and money left over for the EF-S 60mm Macro.
As I have not been able to find a shop or someone with either of the 2 EF-S Im wanting others feed back on their quality before I decide to purchase.
It will be a while before I move to full frame so thats not an issue.
I have checked a few reviews and the feeling is that they are both good lens not "L" but still good and sharp would this be correct?
https://tonysearle.co.​nz (external link)
StealthLude
Dec 21, 2005 00:54 |  #2
I rather get the 100mm Macro instead of a 60mm.. WHY, just because its not EFS.
However i do own a 10-22, and LOVE the lens! I did have the 17-40 and its also a wonderful lens. But i sold it for the 10-22 because the WIDE is just AMAZING WIDE....
It will prolly be the only EF-S lens id ever own... But i have no regrets buying it. Good investment for a 1.6 crop camera.
[[Gear List]]
Skype: Stealthlude
jojohohanon
Dec 21, 2005 12:45 |  #3
Both the 10-22 and 17-85 are great lenses. The 10-22 is the better of two from a quality standpoint, but the 17-85 is amazingly flexible. If I had to do it again, I _might_ go for the tokina 12-24 and the tamron 28-75, but it's a toss up.
ScottE
Joined Oct 2004
Dec 21, 2005 15:39 |  #4
I have the 10-22 for my 20D, and also carry a 28-135 IS for a compart two lens, general purpose kit. I believe the 28-135 compliments the 10-22 better than the 17-85 because there is no overlapping zoom range and an insignificant gap in coverage. The 135 mm is much better for telephoto shots than 85 mm.
If I need a longer telephoto, I add my 50-500 to the kit.
MrChad
Joined Aug 2004
Dec 21, 2005 15:46 as a reply to  @ ScottE's post |  #5
If you are using an APS-C digital I would argue nothing made by Canon (or others) can touch the FOV, or optical quality of the 10-22mm will provide for you.
The 17-85mm IS from what I read is an amazing lens, but if you really liked the look from the viewfinder of the L glass it will leave you wanting. You may want to opt for the 17-40mm f4L over the 17-85mm f4-5.6 IS. You will likely love the pop that much more.
I kaNt sPeL...
[Gear List]
Ricko ­ of ­ Fla
Dec 21, 2005 16:55 |  #6
I have the 17-85 and it is a good lens and for your 10-22.You should go with the Tokina 12-24 a lot of members use the Tokina instead of canon, I also have the Tokina and it is under $500., $200 less than Canon and it does the same job
Smell the Roses and do not forget to shoot the Roses as you go through life. Slow down America and enjoy life :p
5 D II 20D- 300 L f4 400 L f5.6 70-200 L 2.8 24-70 L 16-35, Canon G11
StealthLude
Dec 21, 2005 17:13 |  #7
ive been very curious to try the Tokina as well... ONLY because i hear the build quality it great. BUT!!!! I went with the canon 10-22, because YOU JUST CANT GO WRONG buying that lens. Ive used it a lot, and like another member on this forum said... it would be a cold day in hell before you could pry that out of my hands. =)
Im sure the tokina is a fine lens too, but for an APS-C sensor, im sure the canon will hold its own as far as resale value should i ever decide to go FF body.
[[Gear List]]
Skype: Stealthlude
twotimer
Dec 21, 2005 23:03 |  #8
This picture was taken with the Canon 10-22mm EFS using my Digital Rebel. I am very pleased with the lens although you can get some weird effects on objects close to you.
Gerhard
Jack_C
Joined Dec 2003
Dec 22, 2005 00:08 |  #9
The 10-22 and 17-85 are very different lenses.
The 10-22 is a excellent super wide lens, just excellent, but the 22m may be limiting for you. I assume you dont want to carry the 50-500 all the time!
The 17-85 is a nice walk around lens, its very sharp on the long end, but will be some what softer than the 10-22 on the wide end.
I think your question is do you want wider than 17, some like the super wide end, others do not.
In the end you will probably want both, or a 10-22, 24-105, 50-500 setup.
weka2000
Gallery: 145 photos
Dec 22, 2005 02:01 as a reply to  @ Jack_C's post |  #10
I found that im always swaping between the 17-40 and 50-500. I did find that for most of the time 17mm was wide enough, if I wanted wider I just took 3 shots and stiched.
Often times when im out I photgraph birds and 40mm just dosnt cut it. 75% of the time its the 50-500 that I use and as the weight does not worry me its my "walk around lens"
Based on looking at the exif data im using 17- 135 most of the time when i go to beaches and waterfalls.
I do like the sharpnes of the "L" but I have found that my 18-55 in daylight does ok.
Oh well half the fun is the research on what to get next.
1,508 views & 0 likes for this thread, 8 members have posted to it.
Landscape EF-S lens
2174 guests, 129 members online
