Thread started 21 Aug 2012 (Tuesday) 11:50
1st attempt at combining RAW files - opinions please
2slo
Gallery: 1113 photos
Joined Oct 2011
Aug 21, 2012 11:50 |  #1
Two files made from one here in that I dragged the exposure down on the sky to try to give it an overcast imminent storm look and combined that with a, hopefully, correctly exposed foreground in an attempt to create something interesting. This is my first attempt at anything like this and I'd value constructive comments. Thanks :)
IMAGE: http://farm9.staticflickr.com/8442/7832150444_30351aec89_b.jpg
erikfig
Joined May 2012
Aug 21, 2012 12:03 |  #2
Looks like a great job to me :P
Who cares about my gear?
FlickR (external link)
Facebook (external link)
gen2roller
Joined Oct 2011
Aug 21, 2012 14:50 |  #3
looks great other than the pole in the middle haha
7D Gripped | 5D MKII Gripped |Canon 50mm f/1.4 | 70-200L f/2.8 IS II | 16-35L f/2.8 II | Opteka 6.5mm Fisheye | Cybersyncs and Vivitars
Brian Sorg
www.facebook.com/bsorg​photo (external link)
www.bsorgphoto.bigcart​el.com (external link)
KirkS518
Joined Apr 2012
Aug 21, 2012 15:10 |  #4
gen2roller wrote in post #14888015 (external link)
What he said. Now you get to practice your cloning skills! ;)
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
Christopher ­ Steven ­ b
Aug 21, 2012 15:42 |  #5
Looks pretty good and balanced to me. If you were to 'finish' the shot, you would level the horizon and clone out the pole as discussed. Also--do I see the transition line above the horizon ?
christopher steven b. - Ottawa Wedding Photographer
www.christopherstevenb​.com (external link)| Blog (external link)
2slo
Joined Oct 2011
Aug 21, 2012 15:45 |  #6
erikfig wrote in post #14887254 (external link)
2slo
Joined Oct 2011
Aug 21, 2012 15:49 as a reply to  @ 2slo's post |  #7
KirkS518 wrote in post #14888113 (external link)
Staring right at me and I never noticed it :o
Pole? What pole :)
IMAGE: http://farm8.staticflickr.com/7113/7833632450_edbc4b53d6_b.jpg
drveede76
Joined Dec 2011
Aug 21, 2012 23:46 as a reply to  @ 2slo's post |  #8
Whats wrong with the pole???
6D, 24-70L 2.8 ii, 16-35L 2.8, 70-200L 2.8 IS ii, 24-105L
shutterpat
Gallery: 33 photos
Best ofs: 11
Aug 21, 2012 23:55 |  #9
If you look closely...I would have clone that guy standing right next to the tree instead of the pole....hehehe ;) With or without pole, I likey the shot for the simple reason that it's not overcooked unlike others I've seen. Nicely done, Mark.
2slo
Joined Oct 2011
Aug 22, 2012 03:21 as a reply to  @ shutterpat's post |  #10
Thanks Pat. Quite right, I deliberately wanted to start with a simple shot, I'm not up to attempting anything complex in this new (to me) area of photography yet.
2slo
Joined Oct 2011
Aug 22, 2012 03:28 |  #11
Christopher Steven b wrote in post #14888275 (external link)
Sorry I missed this comment, you must have overlapped one of my replies.
Thanks. I didn't know the horizon needed levelling (but then I've always been hopeless at drawing straight lines) which way and by how much?
You possibly can see the transition line above the horizon, yes. I used a soft brush with the eraser tool in PS to expose the foreground. I did it carefully so is there a better method?
navydoc
Gallery: 236 photos
Aug 22, 2012 09:07 as a reply to  @ 2slo's post |  #12
In this case, where there is a small strip of blue color at the horizon, you could add a hue/saturation adjustment layer. Use the color picker to select the blue (it will choose cyan) and then reduce that colors saturation.
Here's a quick example...I also increased contrast a bit and lowered the brightness.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/08/4/LQ_611518.jpg
Image hosted by forum (611518) © navydoc [SHARE LINK]
2slo
Joined Oct 2011
Aug 22, 2012 09:37 as a reply to  @ navydoc's post |  #13
/\Thanks for taking the time Navydoc, points noted :)
troutfisher
Gallery: 23 photos
Aug 22, 2012 10:15 |  #14
You asked in one of your other posts if there was a better method than using the eraser tool.
I don't know if this method is better but it is an alternative , I have found with photoshop that there is usually more than one way of achieving the end result ,it depends on what method you are happy with.
I appreciate this is overcooked but this is to show the effect and as you have image editing turned on I have had a play so I hope you dont take offence.
All done using CS5, I don't know if other versions have the same tools
IMAGE: http://merlinphotographics.zenfolio.com/img/s4/v64/p7601060-4.jpg
Start by making a copy ( Ctrl J)
1) Straighten the horizon using the ruler tool,rt click on the eyedropper to open it up,click on one end of the horizon,draw a line to the other end,click on the end and then click straighten on the top tool bar.
2)
Use the marquee tool to select the sky down to the horizon,then layer>new layer>layer via copy.
That will put the sky on a separate editable layer.
Then layer>new>new adjustment layer ( I used levels) but at this point you can select any adjustment layer ( purple skies if you want)
The important bit here is to tick the clipping mask box in the adjustment layer dialog box,this restricts changes to the layer below the adjustment layer,if you don't do this the adjustment layer will affect the whole image.
Then alter the sky to get the affect you want.
I tend to turn off the layers I am not working on so I can see what I am doing.
By working in layers you can alter various bits of the image independantly( I have boosted the foreground contrast a bit,but I like saturated colours,not everyone does.
I have taken out the blue line on the horizon but with hindsight I think it looks better with the line left in.
It took ages for me to get my head round layers and masks but they are worthwhile learning.
Regards
Chris
" Age and treachery will always defeat youth and enthusiasm"
2slo
Joined Oct 2011
Aug 22, 2012 10:35 as a reply to  @ troutfisher's post |  #15
/\ That's really helpful Chris, thanks for taking the time, I'll print those stages and methods and try them for myself :)
1,637 views & 0 likes for this thread, 9 members have posted to it.
2432 guests, 103 members online
