I rented a 100-400mm lens when I put it on my 60D there's about an
1/8 inch or so of play rotationally. My 18-135mm and 50mm both fit tight with no play.Is this play normal.
Thank You
John
Aug 21, 2012 19:57 | #1 I rented a 100-400mm lens when I put it on my 60D there's about an
NatureNut Goldmember 1,366 posts Likes: 2 Joined May 2012 Location: NY More info | Aug 21, 2012 20:04 | #2 On a rental lens I would imagine its probably seen a lot of use and abuse. I would suspect that is the cause of your play. The 100-400 I had sat snug on my body with no play. Adam - Upstate NY:
KhanhD "I need a grip . . . on my life" 1,523 posts Likes: 5 Joined Jun 2009 Location: Boston, MA More info | Aug 21, 2012 20:45 | #3 Look and see how much wear is on the recess for the lock pin. Khanh Duong | KHDPhoto.com
Forgot to add this is the second lens from the same rental company (they sent me this one free for comparison)that is doing this I am going to try it on
macroimage Goldmember 2,169 posts Likes: 2 Joined Aug 2007 More info | Aug 21, 2012 22:05 | #5 JM45ACP wrote in post #14889821 Could this cause the camera to take out of focus pictures. Usually it is the UV filter that does that. Too much rotation would cause the lens to eventually loose contact and the camera would behave as though it doesn't have a lens attached.
Usually it is the UV filter that does that The lens doesn't have a filter.
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Aug 21, 2012 23:11 | #7 A wink of rotation movement is okay... an 1/8 inch is A LOT more than a wink of play. I'd be afraid to use a lens with that much slop in the mount. Alan Myers
| Latest registered member was a spammer, and banned as such! 2857 guests, 152 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
