I picked up a used 400 2.8 IS off FM over the weekend and received it today. Got a chance to check it out this evening and everything seemed fine. Glass is clean, IS is working, AF is accurate, fast and smooth. However, I then turned the IS off and the lens won't even try to focus. I can hear it clicking inside, but nothing happening. This only happens WITH THE IS TURNED OFF. This is a problem as the lens will likely live on a gimbal and I need to be able to turn the IS off.
Date code on the lens is UN and I assume Canon would still service it as they just upgraded. However, not sure I want it serviced or if I want to send it back. Given what the 400s with slightly newer date codes are going for, I got what I feel like is a pretty good deal.
Anyone have this happen before? Is there something I am missing (not my first super) or is ther a legitimate problem here?
