Hi Rob,
This is indeed a treasured shot and I'm sure your family will be very pleased with it
I hope you don't mind but I have also made a minor adjustment or two to reduce the yellow cast a little.
| HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by ADVERTISEMENT |
After adjusting the curves a little (I'm afraid I forgot to note the values) and altering the colour balance to -9, 0, +16, I used PS's despeckle filter to reduce the noise that the adjustments brought out. With this being a scaled version it has given the image a slightly 'painted' effect but with the same adjustments on the full size image this shouldn't be so apparent.
KO
EDIT: Sorry, forgot to add that after colour balance adjustments I added a cyan photo filter at 25%
