Thread started 24 Aug 2012 (Friday) 21:20
How to calculate equivalent f/stops on Zoom lenses
pinbingham
1 post
Joined Aug 2012
Aug 24, 2012 21:20 |  #1
Okay so I have searched the internet quite a bit and can't find an answer. I know that zoom lenses have different maximum apertures usually listed on the lens. What I want to know is, how do I calculate an equivalent reading if I am shooting something at 35mm at f/8, then zoom to 90mm? Obviously the photo is underexposed if I shoot at 90mm at f/8, so is there a way or an equation to figure out the correct equivalent exposure?
Thanks!
tracknut
Joined Jun 2005
Aug 24, 2012 22:34 |  #2
You may need to clarify your question. Yes, *some* zoom lenses have different maximum apertures at the two extreme focal lengths, but 35mm f/8 is the same exposure as 90mm f/8. Exposure will be determined by f-stop + shutter speed + ISO, and not focal length.
Dave
Performance/sport dog photographer (external link)
Facebook (external link)
"Always available to shoot your dog"
ejenner
Gallery: 98 photos
Joined Nov 2011
Aug 25, 2012 21:52 as a reply to  @ tracknut's post |  #3
Yes, just to make this clear, the f-stop is a ratio, so the aperture (size of the lens opening) will be larger at 90mm than at 35mm for the same f-stop giving the same exposure.
I think I got the right definition of aperture there, but in any case the principle is correct.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
JeffreyG
Gallery: 42 photos
Aug 25, 2012 22:03 |  #4
f/8 is f/8, so the focal length is irrelevant. A correct exposure at 24mm will likely be a correct exposure at 90mm if you carry over the same f-stop, shutter speed and ISO.
Nature ­ Nut
Joined May 2012
Aug 25, 2012 22:04 |  #5
Just to add, it is all relative to the size of the lens. Ie: a bigger focal length requires a bigger aperture but its in a direct relation to the lens to achieve the same light input. What is underexposed on one lens at F8 is for simplicity sake equally underexposed on any lens at f8 using the same shutter speed and ISO.
read this:
http://www.punitsinha.​com …perture_focal_l​ength.html (external link)
As for figuring out proper exposure based on aperture you can try to use the sunny 16 rule:
http://en.wikipedia.or​g/wiki/Sunny_16_rule (external link)
Adam - Upstate NY:
Sirrith
Gallery: 50 photos
Joined Nov 2010
Aug 26, 2012 07:07 |  #6
pinbingham wrote in post #14903396 (external link)
Where did you get that idea?
Focal length has no appreciable effect on exposure.
-Tom
Preeb
Gallery: 151 photos
Joined Sep 2011
Aug 26, 2012 08:22 |  #7
Thanks!
f8 is f8, focal length is immaterial. If the image is underexposed at 90mm, then that portion of the image will be underexposed at 35mm.
Rick
6D Mark II - EF 17-40 f4 L -- EF 100mm f2.8 L IS Macro -- EF 70-200 f4 L IS w/1.4 II TC
chauncey
Aug 26, 2012 08:23 as a reply to  @ Sirrith's post |  #8
I might take issue with that...you are correct if you assume the same field of view, however...if you zoom in/out without moving, you are changing the field of view, and the exposure, by doing away/adding possible dark/light areas.
Lowner
"I'm the original idiot"
Aug 26, 2012 08:35 |  #9
chauncey wrote in post #14908059 (external link)
Yeeees, OK, if you say so. I'd say thats pretty unlikely to occur each and every exposure!
I'm with the majority here, in that the aperture size is the same if it reports as the same. The camera is not stupid, it knows what lens you are using and the reported metering info in the viewfinder includes the f/no.
I imagine the OP is thinking about a lens like the 100-400 L which offers f/4-5.6 depending on the focal length. Its a non issue, as the metering suggestion copes with it and you the photographer should always exercise those brain cells before blindly firing anyway.
Richard
Sirrith
Gallery: 50 photos
Joined Nov 2010
Aug 26, 2012 09:17 |  #10
The changes in exposure you're talking about aren't a result of changing focal length per se.
-Tom
Nature ­ Nut
Joined May 2012
Aug 26, 2012 09:59 |  #11
Sirrith wrote in post #14908191 (external link)
Agreed, if one happens to own a fixed aperture then their exposure should remain the same. But to save money usually you lose a stop or two with the average telephoto lens.
Adam - Upstate NY:
essvee
Aug 26, 2012 13:32 as a reply to  @ Nature Nut's post |  #12
Point of clarity: f-stop refers to the ratio of the shutter opening to the *diameter* of the lens not the focal length. Therefore f/8 at 90mm zoom is the same opening as f/8 at 35mm zoom. The light falling on the sensor or film will be the same (provided the re-framed composition has similar lighting/contrast).
Wilt
Aug 26, 2012 13:58 |  #13
essvee wrote in post #14909086 (external link)
No, in f/4 on a 200mm lens, the aperture is 50mm...aperture/FL is 50/200 is 1:4 is f/4
In optics, the f-number (sometimes called focal ratio, f-ratio, f-stop, or relative aperture[1]) of an optical system is the ratio of the lens's focal length to the diameter of the entrance pupil
sandpiper
Aug 26, 2012 14:04 |  #14
err, no. It's the focal length.
The "f" in f/8 stands for "focal length". f/8 is literally "focal length divided by 8" the same way as a quarter (1/4) is 1 divided by 4.
The opening (aperture) at f/8 is NOT the same at 90mm zoom and 35mm zoom. At 90mm the opening will be 11.25mm (90 / 8) and at 35mm it will be a 4.375mm opening.
Oh, and the shutter opening is a fixed size and is at the back of the camera, the aperture is in the lens, a totally separate mechanism.
Lowner
Aug 26, 2012 14:31 |  #15
sandpiper wrote in post #14909201 (external link)
Sandpiper,
I owe you one! You have increased my photo knowledge. I never knew that the "f" in f/no was shorthand for focal length. Yes, I knew the ratio bit, but for some reason I never asked the obvious question.
Richard
4,572 views & 0 likes for this thread, 13 members have posted to it.
2536 guests, 91 members online
