Thread started 24 Aug 2012 (Friday) 22:19
40D screws stripped
daniellwells
1 post
Joined Aug 2012
Aug 24, 2012 22:19 |  #1
I was attempting to remove the back panel to replace my broken LCD and the two screws next to the viewfinder are now stripped.... I'm at a loss and have no idea where to go from here :(
kwando
Aug 24, 2012 22:47 |  #2
I don't think you need to remove anything. Look at the top sticky post, I believe the 40d rear LCD cover is removed by a suction cup
~Simon~
My Gear | My Feedback | Smugmug (external link)
https://photography-on-the.net …/showthread.php​?t=1213134
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Aug 25, 2012 03:40 |  #3
If you're using average or dodgy tools, I'd start by buying some really good quality screwdrivers before going any further - a decent set of phillips head 0, 00 & 000 will get most jobs done here.
If the heads are completely stripped (it happens!) then your only real next move is either grind the heads off or drill them. It depends on what tools you have. In my case it was the heads (both screws) on the IR filter cover that wouldn't budge due to loctite and all I had at the time was small drills. Drill using a 1mm drill until just the head comes off so you can take the back cover off - once the cover is off completely you can go further and drill the remaining screw body out. Use a drill size that will leave the threads intact and then tap the hole to suit the original size if possible. While drilling, get someone to hold a vacuum cleaner close so as much swarf as possible doesn't go into the camera!
10D sensor with stripped IR filter holder screws with heads removed prior to being drilled & tapped:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/08/4/LQ_611882.jpg
Image hosted by forum (611882) © joeseph [SHARE LINK]
p.s. I think the screws you're talking about screw the back cover to the top plate assy, so if you're really worried about getting the swarf in the works, take the top cover off and do the drilling well away from the sensitive bits...
TF posting: here :-)
1,326 views & 0 likes for this thread, 3 members have posted to it.
40D screws stripped
2713 guests, 157 members online
