Thread started 25 Aug 2012 (Saturday) 08:06
Low light + 85mm 1.8 ---> 1/160 not enough?
Earwax69
Joined Jul 2012
Aug 25, 2012 08:06 |  #1
Hi, I'm back from shooting a firework display. (not the fireworks but the people under!) I've put my t3i to manual, 1/160, f1.8, ISO 3600. Most pictures are correctly exposed or can be with a little push from Lightroom. However 75% of my pictures got some motion blur in it. I've selected 1/160 because I though it was roughly double of 85mm but now I am kicking myself because I am on a crop sensor and the 85mm is equivalent to a 136mm lens. I should have selected 1/320 or at least 1/250.
It was my first night shooting experience and I really had the time of my life trying to get my shots without anyone noticing me. It's more easy than I though. If you stay at the same place for a while, nobody notice you anymore.
Then, what do you think?? 85mm, f1.8, 1/320, ISO 3200 should do the trick?
Edit: Now I read that the rule is to equal the mm... 1/50 for a 50mm lens. This is clearly not working for me for street photography as I tend to snap my shots quite fast.
Canon 6D | S35mm f1.4 | 135mm f2 The rest: T3i, 20D, 15mm f2.8, 15-85mm, 24mm f2.8, 50mm f1.8, 85mm f1.8, 90mm f2.8 macro, 55-250mm.
So long and thanks for all the fish
Ripple
Aug 25, 2012 09:53 |  #2
You sure it's motion blur as opposed to focus/softness issues? Low light + shallow DoF could mean that you missed the intended focus point. Add to that some softness at 1.8 and high ISO noise.....
LeeRatters
Aug 25, 2012 10:29 |  #3
As said there could be 2 issues here. The camera shake rule won't apply for moving subjects, you'll more than likely need faster again.
>> Flickr << (external link)
>> Instagram<< (external link)
John ­ from ­ PA
Joined May 2003
Aug 25, 2012 12:21 |  #4
You were on the right track previously when you mentioned that the crop factor needs to be applied. So a 50mm on a 1.6 crop would mean the rule of thumb would dictate 1/80 sec or less. Having said that much is up to the photographer. Some people are just not steady enough that the rule apples. Keep in mind that the rule is a throwback to the film days when there wasn't anything called crop factor.
I am assuming you have some fireworks tracks in the photos? If so examine them carefully. If you are holding the camera steady enough the tracks will form a nice smooth track. If you are not steady enough, you will see a jagged appearance to the tracks.
KnightRT
Aug 25, 2012 13:28 |  #5
Crop factor doesn't directly impact handshake. The only relevant factor is pixel size. There's no difference in handshake tolerance between a 30D and a 5D II. Both require 25% faster speeds than film, which we might assume has 4000x2500 resolution in most cases. The 7D/60D/18MP et. al., with pixels 35% smaller on each axis than the other two digital bodies, will require shutter speeds another 35% faster.
On a modern cropped digital body or a full-frame sensor like the D800, I'd try for double the focal as a minimum.
Earwax69
Joined Jul 2012
Aug 25, 2012 13:31 |  #6
I'll post some exemple:
Sharp enough for me:
IMAGE: http://s10.postimage.org/gwnlvclvb/Steady_enough.png
Not sharp enough:
IMAGE: http://s10.postimage.org/ee1wuo053/Not_steady_enough.png
An obvious motion blur 100% crop:
IMAGE: http://s10.postimage.org/l38gaolh3/Motion_blur.png
One of the 20% that came out sharp:
IMAGE: http://s10.postimage.org/41fm8l6lz/Sharp_one.png
Clearly I am not steady enough. But I have to admit that I tought I would be safe at 1/160 and didn't stop my breath or steady my arms against my chest or anything.
Problem is, I think if I push the shutter more, It will make the ISO noise stronger because of the darker, underexposed image. I was quite on the limit tonight.
How much gain in shutter speed f1.4 would make over f1.8?
John ­ from ­ PA
Joined May 2003
Aug 25, 2012 14:26 |  #7
There different f-stop scales but the most common is the full stop scale that runs from f/1, f/1.4, f/2, f/2.8, f/4, f/5.6, f/8, f/11, f/16, f/22, f/32, f/45, f/64. It goes higher but you aren't likely to find it on a lens.
To answer your question you need the 1/3 stop scale which runs from 0.7, 0.8, 0.9, 1.0, 1.1, 1.2, 1.4, 1.6, 1.8, 2.0, 2.2, 2.5, 2.8... From 1.4 to 1.8 is two steps, thus 2/3 of a stop more. Holding f-stop the same, that's the equivalent of going from 1/160 sec to 1/100 sec.
A good guide to everything exposure related is at http://www.fredparker.​com/ultexp1.htm (external link).
Earwax69
Joined Jul 2012
Aug 25, 2012 15:09 |  #8
Ok thanks. 1.5x difference. Quite good.
Sad the Canon 50mm f1.4 is not as sharp wide open as the 85mm.
xarqi
Aug 25, 2012 17:56 as a reply to  @ Earwax69's post |  #9
OP:
I don't see the example images.
KnightRT wrote in post #14905606 (external link)
What leads you to this peculiar conclusion?
crbeveri
Joined Aug 2011
Aug 25, 2012 18:16 |  #10
The rule I was taught for hand held is you wanna try and get 3x the focal length. So if you're shooting an 85mm lens then you want a shutter speed of 1/255 so 1/250th or faster to prevent camera blur from hand shake. I personally do not have the most steady hands and so this holds true for me. This is not be the same for everyone as I know people who can hand hold a 500mm f/4 at 1/250th and get tack sharp images.
If shooting at such a low light is what you enjoy I would say you've maybe started to reach the limit of your body as your glass looks good. Perhaps upgrade a body that will allow you to push the ISO a bit more to get a faster shutter speed.
I shoot a little black box with a round thingy ma-giggy in the front.
The gear list (external link)
Gatorboy
Aug 25, 2012 18:22 |  #11
xarqi wrote in post #14906319 (external link)
OP:
OP didn't post .JPGs ... tried to display .PNGs
Dave Hoffmann
Earwax69
Joined Jul 2012
Aug 25, 2012 19:33 |  #12
OP:
Ha yes, The hosting site kept them in PNG. I though it would be converted to jpeg. What browser are you using? It load ok on firefox but not on my Iphone.
(facepalm)
I've bought the T3i last month, and a 15-85mm few days ago! :( - Seriously, I enjoy shooting night time but I would rather get a 135mm f2L than a 5D markii.
Maybe next year!
For the handshake thing, one solution would be to use a 50mm lens and not the 85mm. That would make the 1/160 shutter speed ok. Also I just might try to jump to 1/320 and get away with it with the 85mm.
Should I dare bump the ISO to 6400?
Earwax69
Joined Jul 2012
Aug 25, 2012 21:44 |  #13
I am slightly shocked. I've just tried the same settings with my 15-85mm lens. even at f5.6, 1/30, the 85mm end give me a lot more sharpness than the 85mm f1.8 at 1/160. The IS really make all the difference in the world.
However, yeah... no nice bokeh.
It also make me wonder about a lens like the 70-200mm f4 IS USM. It could actually be used in extreme low light at ISO 1600.
I was planning to get the 135L as my next lens. Now I am not so sure anymore.
rrblint
Gallery: 84 photos
Joined May 2012
Aug 25, 2012 21:56 |  #14
John from PA wrote in post #14905763 (external link)
I think OP wanted to go from f1.8 to f1.4...Therefore the SS would go from 1/160 to 1/250.
Mark
xarqi
Aug 26, 2012 00:20 as a reply to  @ rrblint's post |  #15
Earwax69 wrote in post #14906567 (external link)
Firefox 3.6.28 on OS X 10.4.11.
6,692 views & 0 likes for this thread, 12 members have posted to it.
2829 guests, 162 members online
