Earwax69 wrote in post #14911936
That explain why tamron dont get all this front focussing nonsense.
No
Expanding on what John from PA and gjl711 and said:
With regards to focus, imagine 0 as perfect - which, as gjl711 noted, is quite difficult to acheive. Camera and lens manufacturers can't trash every lens and camera that isn't perfect, so they build within tolerances, let's say -20 to +20.
If your camera body is -8 and your lens is +8, you'll have, essentially, a perfect combo. Even if it's -9 and +12, it will still be pretty good. But when you start getting high-value same-sign numbers, like +17 and +19 or -20 and -16, you'll find noticeable front- or back-focusing. Just remember, each copy of every lens and every body can and will be different.
So your 28-70 might be a -10 lens, which is within tolerance. Your 20D might be a +8 body, which is also within tolerance. Together, they focus pretty damn well. OTOH, your 600D might be -10. Suddenly, you start noticing that the focus isn't quite where it should be.
Note: all numbers are arbritrary and for illustration purposes only.
