While in the develop module, if I click on a preset and it applies it to my image, then click on another preset, will it apply the preset to the original image or to the modified one? Thanks for any insight.
dan.k78 Senior Member 426 posts Likes: 14 Joined Mar 2009 Location: Cheektowaga, New York More info | Aug 27, 2012 15:14 | #1 While in the develop module, if I click on a preset and it applies it to my image, then click on another preset, will it apply the preset to the original image or to the modified one? Thanks for any insight. Gear: 5DIII; 6D; Canon 16-35 f/4L; Canon 24-70II f/2.8L, Tamron 70-200mm f/2.8 VC; Sigma 35mm f/1.4A; Sigma 105mm f/2.8 Macro; Phottix Mitros+;580exii; Metz AF 50-1
TustinMike figment of our collective imaginations More info | Aug 27, 2012 15:19 | #2 I seem to recall reading in Kelby's LR 2 book that presets are additive,however I don't know if that was correct (or maybe it's different for LR4), because to me it looks like the presets apply to the base image. I'm mainly here for the snacks
PerfectTan Senior Member 440 posts Joined Aug 2010 Location: Washington More info | Yes, but if you go to the History(left panel) and click on the previous preset . You should be able to go back to previous setting. Do not click on Reset(the right side) -you could, but will have to start over again. My Gear: Do you really want to know?
Merovius Member 233 posts Likes: 2 Joined Jul 2011 Location: Mile High City More info | Aug 27, 2012 18:54 | #4 It's not additive, but the overall effect depends on what's included with the preset. When you're creating a preset, you have the option to select the settings that are included. Many (most, probably) presets are created with ALL available slider settings included, regardless of whether they've been touched or not. With a preset like that, when applied it resets all the sliders that were untouched during its creation to default, essentially wiping out any changes made by a previously applied preset. --Howard
dan.k78 THREAD STARTER Senior Member 426 posts Likes: 14 Joined Mar 2009 Location: Cheektowaga, New York More info | Aug 27, 2012 19:36 | #5 Thanks for the info. Sounds like I should do some experimenting... Gear: 5DIII; 6D; Canon 16-35 f/4L; Canon 24-70II f/2.8L, Tamron 70-200mm f/2.8 VC; Sigma 35mm f/1.4A; Sigma 105mm f/2.8 Macro; Phottix Mitros+;580exii; Metz AF 50-1
Mark1 Cream of the Crop 6,725 posts Likes: 7 Joined Feb 2008 Location: Maryland More info | Aug 27, 2012 19:37 | #6 It is sorta additive. A preset is nothing more than a list of sliders and what value to set them to.Just open one in a text editor and you will see. If the author didnt include a specific slider in the preset it will not be touched. Example preset #1 moves contrast to 75, saturation to -23. Then you try preset #2 and it moved contract to 12. But has no call to adjust saturation... The slider will stay at -23. And this will give you a different effect than you would have if you has clicked on #2 first.
smooth3000 Goldmember More info | Aug 28, 2012 10:04 | #7 |
| Latest registered member is semonsters 1062 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
