Ratjack wrote in post #14919729
You can always overclock your CPU. That will help as well. Is your CPU the 2600K or a 2600? If its not the K version then you can still overclock is slightly as long as you have a p67, z68, or z77 motherboard. I believe you can overclock it and change the multiplier up to 40 or 42 on the non K CPU. This will achieve a 4.0-4.2Ghz cpu speed. If your on a stock cooler though keep an eye on CPU temps (for this download speedfan or any other monitoring software along with prime95 to test the CPU). An OC will help speed some things up. An SSD is one of the best upgrades for any computer. I replaced all mechanical drives in our computers with SSDs. They are well worth it.
I have the non-K, non-overclock version of the 2nd gen i7. Overclocking is a bit too scary for me (I'll probably toast my PC).
From the all comments, a SSD seems like a good bang for the buck upgrade for about $100. Now the only question is the size - 128G or 256G. If I just port over my catalog and previews, I think 128G is large enough, for now.
