Thread started 28 Aug 2012 (Tuesday) 06:51
7D Focus Points Question
yorkiemom
Aug 28, 2012 06:51 |  #1
Hope I'm explaing this right because all of a sudden I'm not seeing the "red" focus points I used to. Not sure if I changed something, and I have checked it out, but not sure.
I see all "red" focal points showing in my viewfinder when I press down on the shutter. I know I can press the AF point selection/Magnify button and then use the M-Fn button to cycle thru. What I'm looking for I used to be able to see Other AF Functions...like a zone one (where it looks like brackets), one where half right or left is only "red" highlighted, etc. But I'm not seeing that anymore and I'm not sure why. In the Setup C.Fn III No 6...I have enabled them all. Should I be seeing them?
Canon 7D, 40D, IS lenses EF 17-85, EF 70-300 USM, EF 100mm f/2.8 Macro, EF 50mm f/1.4, Tokina 11-16 f/2.8, 70-200 f/2.8L and various other "stuff"
Mornnb
Gallery: 6 photos
Joined Aug 2012
Aug 28, 2012 07:06 |  #2
The 7D will only show the red in the viewfinder if it detects little light, try using it in a dark area.
Canon 5D Mark III - Leica M240
EF 16-35mm F/4 IS L - EF 14mm f/2.8 L II - - EF 17mm TS-E L - EF 24-70mm f/2.8 L II - EF 70-200mm IS II f/2.8 L - Sigma 35mm f/1.4 Art - Sigma 85mm f/1.4 EX
Voigtlander 15mm III - 28mm Elmarit-M ASPH - 35mm f/1.4 Summilux-M FLE - 50mm f/1.4 Summilux-M ASPH
500px (external link)
yorkiemom
Aug 28, 2012 07:10 |  #3
I'm talking about changing the focus points to something other than the normal 19 point and being able to move the box around that.
I am using it in a dark area in my room but the red points don't show up.
huntersdad
Aug 28, 2012 07:15 |  #4
Have you somehow turned those AF choices off? Not sure what C.Fn III No 6 is as I don't have my camera with me.
Facebook (external link)
http://WWW.BLENDEDLIGH​TPHOTOGRAPHY.COM (external link)
1DxII x 2 / 24-70L II / 70-200L II / 85 1.4L / 300 II / AD600Pros
North ­ Dude
Joined Nov 2010
Aug 28, 2012 07:17 |  #5
I don't remember what this does to focus points, but did you put the AF/MF switch on your lens to manual focusing? Maybe this turns of AF choices... (I don't have my camera with me at the moment to test this.)
7D | 100L | Σ 70-200 2.8 OS | Σ 10-20 4-5.6 | Σ 17-50 2.8 OS | Σ 50 1.4 | Σ 1.4x | 580 EX II | other stuff
yorkiemom
Aug 28, 2012 07:18 |  #6
It's where you can choose and expand the focul points. They are all checked but I can't see to get anything except the 19 point. Unless one has to be in a different mode to do that?
apersson850
Aug 28, 2012 07:25 as a reply to  @ yorkiemom's post |  #7
In green box and CA modes, only all points are available.
You have to go to P or beyond to select yourself.
Anders
Mornnb
Gallery: 6 photos
Joined Aug 2012
Aug 28, 2012 07:29 |  #8
When in doubt, clear all custom functions. ;) Did you change any of the other functions in Fn IIII?
apersson850
Aug 28, 2012 08:22 as a reply to  @ Mornnb's post |  #9
If he's in green box or CA, he can't even access any custom functions, let alone clear them.
Anders
AJCanon
Joined Mar 2012
Aug 28, 2012 20:53 |  #10
apersson850 wrote in post #14917061 (external link)
This is true.
But if you are shooting manually, click the Q button to go to the quick control screen. Then go the box that is about the quality setting. use one of the dials(one on back or one on top, doesnt matter) and you can then switch to what you would like.
Canon 7D2, 7D, XS, Sigma 17-50, Canon 10-18, Canon 70-300 USM, Canon 60mm, Speedlite 230exII
apersson850
Aug 29, 2012 02:45 as a reply to  @ AJCanon's post |  #11
How would the quality setting help on selecting AF points?
Anders
Tellairai
Aug 29, 2012 03:57 |  #12
If they are all selected you shouldbe cycling through precision, standard, center+assist, zone and All. From what you are describing you want zone. If you never used it prior it would look like a 9 AF point box.
oldvultureface
Gallery: 76 photos
Aug 29, 2012 05:45 |  #13
C.Fn III -9. Display all AF points (or not).
yorkiemom
Aug 29, 2012 07:01 |  #14
I found that I can scroll thru all in the green box on the screen. Haven't changed anything else in Functions. I'm using AF.
I'm just curious that when I'm focusing none of my focus points show up in red to tell me that is where I am focusing...it's black. Shouldn't red highlight for a brief moment?
oldvultureface
Gallery: 76 photos
Aug 29, 2012 07:13 as a reply to  @ yorkiemom's post |  #15
If you're in AI servo, the point(s) won't light up.
2,737 views & 0 likes for this thread
Latest registered member is karozenix
1054 guests, 310 members online
