Thread started 28 Aug 2012 (Tuesday) 11:44
Weird (new) color change with Canon 9500 Mark II printer
sdipirro
Aug 28, 2012 11:44 |  #1
I was shooting and printing with this combination, and my prints almost exactly matched what I saw on the screen:
- Canon 1D4 body
- Pixma Pro 9500 Mark II printer
- Ilford Gold Fibre Silk photo paper
- Ilford ICC profile
- Photoshop CS5
- Calibrated NEC monitor
And recently changed the following:
- Canon 1D X body
- Photoshop CS5 to CS6
My printed images now have a green cast to them. I was seeing this even before upgrading from CS5 to CS6. So the only real change is the camera body, but that shouldn't make any difference if I open up a JPEG and print it. I typically use the Canon EasyPhoto print plugin for printing, and I can compensate somewhat for the color cast, but I'd rather not do this and have an explanation for it. Any ideas?
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
tonylong
...winded
Gallery: 60 photos
Aug 28, 2012 19:58 |  #2
So, have you viewed the pics in the Photoshop View Proof function, and if so does the image have the green cast or does it appear "normal"?
And, have you printed one of your "older" shots since you've had this problem, and don't get the green cast?
Tony
tonylong
...winded
Gallery: 60 photos
Aug 28, 2012 19:59 |  #3
If you are close to a good print provider you might take a photo in to have it printed and see if you get better results...
Tony
René ­ Damkot
Aug 29, 2012 07:40 |  #4
What happens if you print straight from PS?
Do old files print okay?
Sure your screen calibration is up to date?
I could imagine going from PSCS5 to PSCS6 might break something in the color management chain, but not going from a 1D4 to a 1Dx…
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
sdipirro
Aug 29, 2012 13:11 |  #5
Sorry about the delay in getting back here. The print proofs look normal. In one case, a picture that I printed that had a green cast was also printed by a customer from the same JPEG on my website (smugmug - Bay Photo lab), and I didn't see the customer print but was told it looked great (I realize they might not view it the same way I would). I haven't tried printing an older picture yet, but that's a good idea. I bet it will also have the green cast and point to a printer issue rather than the change in camera bodies. I'll report back after I get a chance to try that. Another thing I haven't tried and will try tonight (because I have to) is print something on Canon paper with a Canon profile and see if that has the same cast.
1,770 views & 0 likes for this thread, 3 members have posted to it.
1700 guests, 139 members online
